Local Time 23:32 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Date Stamp a File
palcal
Posted: 05:32am 04 Mar 2024
I want to save files to an SD card. As so....
Open "A:/test/data" For Output As#1
 Print #1, x;",";y;",";z
 Close #1
Then next day I want to save the same files that will have different values.
How can I Time Stamp them so they are saved separate to the data the previous day.
Posted: 05:49am 04 Mar 2024
You need a different file name, for example:
   Open "A:/test/data"+DATE$ For Output As#1
Alternatively, rename the old file before creating the new one:
   ReName "A:/test/data" as "A:/test/data"+DATE$
Edited 2024-03-04 15:55 by Geoffg
Posted: 05:57am 04 Mar 2024
I tried that but got:-
> Open "A:/test/data"+DATE$ For Output As #2
Error : Could not find the file
This seems to work:
> s$ = "A:test"+datetime$(now)
> Open  s$ For Output As #1
Edit.
the "/" seems to be the issue.
Change to the required directory first then Open and see if that helps.
Edit 2.
> mkdir "test"
> chdir "test"
> s$ = "data_"+DATE$
> files
A:/test
  <DIR>  .
  <DIR>  ..
17:08 04-03-2024          0  data_04-03-2024
2 directories, 1 file, 15032320 bytes free
Edited 2024-03-04 16:10 by phil99
palcal
Posted: 06:06am 04 Mar 2024
Thanks, I'll work with that and see how I go.
palcal
Posted: 06:56am 04 Mar 2024
Thanks, Geoff's example worked for me. I now have it running OK
palcal
Posted: 08:39am 04 Mar 2024
Well it seemed to work. I found after saving the file, I can change Date$ in the line
Open "A:/weather/data"+Date$ For Input As#1
to anything and it still reads the file OK.
I've tried all sorts of things but no go.
palcal
Posted: 06:45pm 04 Mar 2024
Using a PicoMite with V 5.07.06
Still working on this. In the code below I have saved the value 'Z' to "A:/test/tuesday". I then save values to "A:/test/monday". But I can then retrieve these values from "A:test/tuesday". It seems the file name does not matter ?
Option EXPLICIT
Option DEFAULT NONE
Dim Integer x,y,a
Dim Integer Test(12)
Dim Integer z
Open "A:/test/tuesday" For Output As#4
 Print #4, z
 Close #4
 For y = 1 To 10
 Test(y)=y
 Next y
Open "A:/test/monday" For Output As#4
 For a = 1 To 10
 Print #4, Test(a)
 Next a
 Close #4
 For x = 1 To 10:test(x)=0:Next x
 Open "A:/test/tuesday" For Input As#4
 For x = 1 To 10
     Input #4, Test(x)
     Next x
     Close #4
 For x = 1 To 10
 Print x;
 Next x
        ESC:Exit  F1:Save  F2:Run  F3:Find  F4:Mark  F5:Paste  Ln: 11  Col: 3     INS
Edited 2024-03-05 05:49 by palcal
Posted: 07:48pm 04 Mar 2024
  Quote   For x = 1 To 10
Print x;
Next x
should be
Print test(x);
Next x
palcal
Posted: 07:50pm 04 Mar 2024
Thanks Peter, another stupid mistake.
Back to trying to datestamp the file.
Edited 2024-03-05 05:54 by palcal
palcal
Posted: 08:20pm 04 Mar 2024
Ok so I tried this...
Option EXPLICIT
Option DEFAULT NONE
Dim Integer x,y,a
 For y = 1 To 10
 Test(y)=y
 Next y
Open "A:/test/"+Date$ For Output As#4
 For a = 1 To 10
 Print #4, Test(a)
 Next a
 Close #4
 Date$ = "05-03-2025"
 Open "A:/test/"+Date$ For Input As#4
 For x = 1 To 10
     Input #4, Test(x)
     Next x
     Close #4
 For x = 1 To 10
 Print test(x);
 Next x
Using Date$ as the file name but then I change the date to the following year and the code runs OK although the file name has changed. I was thinking Date$ would be expanded into the actual date but obviously not.
I thought Datestamping a file would be simple but obviously not.
Edited 2024-03-05 06:54 by palcal
Posted: 10:23pm 04 Mar 2024
Does this make any difference?
Fname$ = "A:/test/"+Date$
Open Fname$ For Input As #4
For x = 1 To 10
    Input #4, Test(x)
    Next x
    Close #4
For x = 1 To 10
Print test(x);
Next x
PEnthymeme
  palcal said  Ok so I tried this...
Option EXPLICIT
Option DEFAULT NONE
Dim Integer x,y,a
 For y = 1 To 10
 Test(y)=y
 Next y
 For a = 1 To 10
 Print #4, Test(a)
 Next a
 Close #4
 For x = 1 To 10
     Input #4, Test(x)
     Next x
     Close #4
 For x = 1 To 10
 Print test(x);
 Next x
Is the issue here that date$ always returns the current date, regardless of setting it with date$="05-03-2025" in your code.
The above works as expected
OpenDate$ = "05-03-2025"
Open "A:/test/"+OpenDate$ For Input As#4
Modified not to use date$....
Forgive me if I am missing the point here - but the above now works as expected.
Px
palcal
Posted: 11:18pm 04 Mar 2024
Yes it does if you expand Date$. Put simply I want to save a file each month, so I have to use a different file name each month otherwise next month, this months data will be overwrittren. I want the file name to change automatically each month that is why I was trying to incorporate the Date in the file name. Eventually if I get it working I was just going to use the month. Mid$(Date$,4,2) in the file name then I would be able to print out a full years data month by month.
I thought this would be something that is quite common but obviously not.
As Geoff said above...
  Quote  You need a different file name, for example:
But it doesn't work.
Edited 2024-03-05 09:24 by palcal
Posted: 11:41pm 04 Mar 2024
This works for me with data in the editor:
> mkdir "test"
> save "a:/test/data"+mid$(date$,9,2)+mid$(date$,4,2)+".dat"
> files "test/"
A:/test
  <DIR>  .
  <DIR>  ..
18:37 04-03-2024         32  data2403.dat
2 directories, 2 files, 15458304 bytes free
Similar should work with OPEN, PRINT, and CLOSE in a program.
Edited 2024-03-05 09:43 by lizby
Posted: 01:08am 05 Mar 2024
My method:
logtime$ = MID$(DATE$,9,2)+MID$(DATE$,4,2)+LEFT$(DATE$,2)+LEFT$(TIME$,2)+MID$(TIME$,4,2)+RIGHT$(TIME$,2)
logfile$ = "log"+logtime$+".txt"
PRINT logfile$
Just omit the Time$ portion as desired.
palcal
Posted: 01:10am 05 Mar 2024
Thanks Lizby and Jim, I'm half way through mowing 1/2 acre, I'll try it out this afternoon.
palcal
Posted: 03:17am 05 Mar 2024
OK I seem to have it working.
Thanks for the help.
