Local Time 23:32 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMB4W - v5.07.03b24 issue with wine
panky
Posted: 10:49pm 03 Mar 2024
I run MMB4W under wine and it has been working perfectly up to the last release 5.07.03b24
The problem is that the terminal window opens momentarily then closes but the olc window never opens and the program just crashes/closes. All previous version from 5.07.03b23 and earlier have worked perfectly. Numerous other programs work correctly under wine.
Configuration:
Linux Mint Cinnamon 21.2 with wine 6.0.3
If I run b24 with wineconsole, the following error message occurs
doug@G-Mint21:~/MMProgs/MMB4W$ wineconsole MMBasic4W_v5.07.03b24.exe
00d4:err:module:import_dll Loading library XINPUTUAP.dll (which is needed by L"Z:\\home\\doug\\MMProgs\\MMB4W\\MMBasic4W_v5.07.03b24.exe") failed (error c000007b).
00d4:err:module:LdrInitializeThunk Importing dlls for L"Z:\\home\\doug\\MMProgs\\MMB4W\\MMBasic4W_v5.07.03b24.exe" failed, status c0000135
Note that running b23 under wineconsole works perfectly.
Any advice appreciated?
Thanks,
Doug.
Posted: 01:55am 04 Mar 2024
I think you might need Wine 9.3
https://www.thebackshed.com/forum/ViewTopic.php?FID=16&TID=16713#217847
panky
Posted: 10:53pm 04 Mar 2024
Thanks Jim,
Just need to figure out if I need to remove the old (6.0.3) version first then install 9.3 from winehq.
My Linux expertise is pretty basic ( no pun intended   ) but with wine and Virtualbox with Win7 loaded, it does everything I need.
Doug.
LeoNicolas
Posted: 11:30pm 04 Mar 2024
I can help you. I'm not at home right now. I will post a step by step on how to update wine as soon as I arrive home
LeoNicolas
Posted: 04:12am 05 Mar 2024
Hello Doug
I think it is a good idea to uninstall your installed wine because we will need to install the wine developer version (9.3). The current stable version (9.0) doesn't have the patch for the xinput bug.
1) Open your terminal
2) Uninstall wine
sudo apt remove wine && sudo apt autoremove
3) Add the Wine repository keys to your computer
sudo mkdir -pm755 /etc/apt/keyrings
sudo wget -O /etc/apt/keyrings/winehq-archive.key https://dl.winehq.org/wine-builds/winehq.key
4) Add the Wine repository for Ubuntu 22.04, the version which Linux Mint is based on
sudo wget -NP /etc/apt/sources.list.d/ https://dl.winehq.org/wine-builds/ubuntu/dists/jammy/winehq-jammy.sources
5) Update your local package manager software list
sudo apt update
6) Install the Wine Developer version
sudo apt install --install-recommends winehq-devel
7) Check wine's version
wine --version
Edited 2024-03-05 14:13 by LeoNicolas
panky
Posted: 11:23pm 05 Mar 2024
Thanks Leo,
Fell over at step 3
doug@G-Mint21:~$ sudo wget -O /etc/apt/keyrings/winehq-archive.key https://dl.winehq.org/wine-builds/winehq-key
--2024-03-06 10:13:02--  https://dl.winehq.org/wine-builds/winehq-key
Resolving dl.winehq.org (dl.winehq.org)... 151.101.30.217
Connecting to dl.winehq.org (dl.winehq.org)|151.101.30.217|:443... connected.
HTTP request sent, awaiting response... 404 Not Found
2024-03-06 10:13:03 ERROR 404: Not Found.
Any suggestions?
Doug.
Posted: 12:17am 06 Mar 2024
A typo perhaps?
You have :-  https://dl.winehq.org/wine-builds/winehq-key
Step 3 has:-  https://dl.winehq.org/wine-builds/winehq.key
Replace "-" with "."
LeoNicolas
Posted: 01:47am 06 Mar 2024
Yep, it looks like a typo
I recommend you to copy the command from the browser and paste it to the terminal. Use ctrl+shift+v in the terminal to paste the text
toml_12953
Posted: 03:31am 06 Mar 2024
  LeoNicolas said  Hello Doug
Mine fails at step 6:
tom@TOM-HOME-PC:~$ sudo apt install --install-recommends winehq-devel
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
winehq-devel : Depends: wine-devel (= 9.3~mantic-1)
E: Unable to correct problems, you have held broken packages.
Edited 2024-03-06 13:35 by toml_12953
panky
Posted: 04:57am 06 Mar 2024
@phil99 & Leo,
Thanks guys for the assistance - I must have read through that line 20 times and still did not pick up the typo
Finished the sequence and I now have wine 9.3 - after a mono dependency fix - MMB4W_v5.07.03b24 up and running - all good   .
Very much appreciated,
Doug.
