Local Time 01:24 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMiteVGA Updated to 5.09.00b4 - now doesn't boot anymore!
Amnesie
Posted: 04:53pm 02 Mar 2024
Hello,
I now updated the PicoMiteVGA from 5.08 to "PicoMiteVGAV5.09.00b4" and cleared the flash before that.
(if that matters: I am using my very own picoMiteVGA PCB, which follows the (old?) pre USB-version schematics and works fine with 5.08.
But now really strange things happen:
I connect the pico to via its USB to my computer to power it up and nothing happens, monitor will remain black, no signal. BUT as soon is I manually connect via TeraTerm
it suddenly boots and the green pico onboard led blinks, the VGA monitor now works.
Why do I NEED to connect manually via TeraTerm to boot into MMBASIC? With that update I can not use the picoMiteVGA as a stand alone computer anymore :(
Do I miss something?
Problem in short: It only boots into BASIC after connecting manually via TeraTerm...
Greetings
Daniel
Amnesie
Posted: 05:13pm 02 Mar 2024
Ah found out that Peter updated already to VGAV5.09.00b5 ! Now the problem is solved... I can't keep up with all those updates
