Local Time 01:25 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PM: firmware crashes....
Posted: 10:31pm 29 Feb 2024
Hi all.
I have several boards now based on the RP2040 Zero module from WaveShare, becasue it is small and runs the MMBASIC Pico port just fine - usually.
I have a situation, where, for no apparent reason, the firmware seems to crash.
I have no idea really, why this should be.
The unit can go WEEKS of 24/7 with no problems, then it can just crash.
And when I mean crash, I mean crash - the console is gone, nothing works, the buttons don't do anything, and you can only get it back, by cycling the power or pressing the on-board "RESET" tact switch to force the 2040 to reset - then it works again.
I have used the WATCHDOG command in the code, which should be making use of the 2040's built-in watchdog - see the RP2040 datasheet, page 566, section 4.7
Please can someone(Peter?) confirm that MMBASIC for the 2040, does indeed use the 2040's watchdog, or is this watchdog running inside the MMBASIC interpreter, so that if MMBASIC crashes, this would also crash the watchdog timer.
Yes?
No?
I'm at the stage of thinking I should just add an external watchdog IC, such as the Microchip MIC706 for example(only a buck each), but they all expect a 5v MCU system voltage, and the 2040 is 3v3, so IF I decided to add an external watchdog IC, I would need to find a way to interface that 5v chip, to the 3v3 "RUN" pin on the 2040 chip, but I am sure it can be done without too much of a problem - one "Channel" of one of those MOSFET-based level-corrector thing-y's would probably do the job nicely.
Thoughts and comments welcome.
Posted: 11:17pm 29 Feb 2024
Microchip MIC706 datasheet says Vcc 1.4 - 5.5V
Posted: 11:21pm 29 Feb 2024
Are you using WATCHDOG HW xx
The HW watchdog is more robust but has a limited timeout.
Posted: 11:23pm 29 Feb 2024
I know, but the datasheet is confusing, cos in all the examples, they talk about a 5v supply - see the diagram on page 2...
Chart on page 3 says Vcc of 1.4v to 5.5v, but then goes on to mention a "Reset Voltage Threshold" of 4.4v(for the MIC706)
How can you have a reset threshold, that is higher then the supply voltage?
I don't really understand that bit of the datasheet, and am thinking that as soon as you supply it with LESS then 4.4v, it will assert /RESET and never come out of it if VCC remains lower then that.
If you can clarify this head-scratcher, that would be wonderful.
Posted: 11:25pm 29 Feb 2024
  TassyJim said  Are you using WATCHDOG HW xx
NO.
Was unaware of that variation of the WATCHDOG command.
My manual does not say anything in the COMMANDS section about "WATCHDOG HW", just the standard watchdog command.  PM manual version 5.07.06, Revision 1.
EDIT: A-HA!!!!!
I'm using an out of date manual.  Have just grabbed the latest one from Geoff's website. (Version 5.08.00, Revision 4)
Edited 2024-03-01 09:30 by Grogster
Footnote added 2024-03-01 09:32 by Grogster
I've just read the updated manual about WATCHDOG HW, and I will implement that in the code rather then the standard one, and see if that helps me.
Posted: 11:35pm 29 Feb 2024
Maybe we are using different datasheets. The one I have says it is intended for 3V systems and voltage monitoring is via a external voltage divider so can be set to whatever you want.
Posted: 11:55pm 29 Feb 2024
My datasheet came from Microchip:
MIC705 MCU Watchdog Timer IC.pdf
