Forum Index : Microcontroller and PC projects : Advice on GUI PAGE Command
| martrogers Newbie Joined: 15/09/2019 Location: AustraliaPosts: 12 |
Hello All I am coding a calendar type device using a Picomite, ILI9341 and MMBasic 5.08.00. All goes well in sub rel_entry first time round the loop but second time when GUI PAGE 2 is called nothing is drawn on the screen. So I know that GUI PAGE 2 is a permitted screen but don’t know why it will not draw multiple times. I would appreciate some advice on what I’ve done wrong, apologies for the unprofessional code. Regards Martin '1-22 elements used OPTION EXPLICIT OPTION DEFAULT NONE dim integer PDnEf, PUpEf, hourx, dayx, weekx, monthx, choose1 dim integer exit_flag, eflag GUI interrupt penDown, penUp gui beep 300 'click on screen input cls const Enter_new=1 ' button names, so button #1 is called Enter_new const Up=2 const Down=3 const set_months =4 const set_weeks =5 const set_days =6 const set_hours =7 const done =8 const rel_box =9 const hourxx =10 const dayxx=11 const weekxx=12 const monthxx=13 const yearxx=14 CONST abs_box =15 gui SETUP 1 ' screen 1 font #3 'large font gui button Enter_new, "Enter New",0,190,155,50, rgb(black),rgb(lightgrey) gui button Up, "Up", 170,190,50,50, rgb(black),rgb(pink) gui button Down, "Down", 240,190,80,50, rgb(black),rgb(gold) gui SETUP 2 font #3 gui displaybox rel_box,10,0,300,50,rgb(BLACK), RGB(BLUE) CtrlVal(rel_box)="Time to Alarm" gui button set_hours, "Hours",15,55,120,50, rgb(black),rgb(lightgrey) gui button set_days, "Days",15,125,120,50, rgb(black),rgb(lightgrey) gui button set_weeks, "Weeks",180,55,120,50, rgb(black),rgb(lightgrey) gui button set_months, "Months",180,125,120,50, rgb(black),rgb(lightgrey) gui button done, "Done",70,190,200,50, rgb(black),rgb(gold) gui SETUP 3 font #1 gui formatbox 15, DATETIME1, 170,100, 150,50,rgb(black),rgb(yellow) gui SETUP 4 font #3 gui displaybox 16,10,0,300,50,rgb(BLACK), RGB(BLUE) CtrlVal(16)="Repeating?" gui button 17, "Daily",1,60,150,50, rgb(black),rgb(beige) gui button 18, "Weekly",1,120,150,50, rgb(black),rgb(beige) gui button 19, "Monthly",1,180,150,50, rgb(black),rgb(beige) gui button 20, "Yearly",150,60,150,50, rgb(black),rgb(beige) gui button 21, "Custom",150,120,150,50, rgb(black),rgb(salmon) gui button 22, "None",150,180,150,50, rgb(black),rgb(gold) gui setup 5 font #3 gui numberbox hourxx,200,100,120,50,rgb(black),rgb(yellow) gui setup 6 font #3 gui numberbox dayxx, 200, 100, 120, 50, rgb(black), rgb(yellow) gui setup 7 font #3 gui numberbox weekxx, 200, 100, 120, 50, rgb(black), rgb(yellow) gui setup 8 font #3 gui numberbox monthxx, 200, 100, 120, 50, rgb(black), rgb(yellow) do select case TOUCH(REF) ' will return 1 if button 1 is touched, 2 for button 2 etc ' case Enter_new ' Enter_new button touched ''new_entry 'subroutine for this touch cls font #2 ' display screen asking absolute or relative entry choose1 =MsgBox("Absolute or Relative Alarm~ Abs e.g 10 May 3:30PM~Rel e.g 5 days,10 hrs","Abs","Rel","Exit") select case choose1 case 1 abs_entry 'absolute date case 2 'relative time (timer) rel_entry end select ' 'case Up 'scroll_up 'case Down 'scroll_down end select loop sub rel_entry exit_flag=0 do 'keep returning to this screen to allow Weeks + Days+ Hours etc to be input eflag=0 print "at Page 2" pause 700 cls gui redraw all gui page 2 ' hrs, days, weeks, months, done buttons gui redraw all print "past Page 2" do select case TOUCH(REF) ' will return 1 if button 1 is touched, 2 for button 2 etc case 7 ' Hours selected, input number of hours cls gui page 5 CtrlVal(hourxx) = "##Hours" 'print "Hours selected" do if PDnEf=1 then 'input box touched PDnEf=0 hourx=ctrlval(hourxx) end if if PUpEf=1 then ' numbers entered and ENT touched, ENT generates a Pen Up interrupt PUpEf=0 hourx=ctrlval(hourxx) 'numbers pressed if hourx>0 then eflag=1 exit do endif end if loop print "hours" hourx case 6 'Days cls gui page 6 CtrlVal(dayxx) = "##Days" print "Days selected" do if PDnEf=1 then 'input box touched PDnEf=0 dayx=ctrlval(dayxx) end if if PUpEf=1 then ' numbers entered and ENT touched, ENT generates a Pen Up interrupt PUpEf=0 dayx=ctrlval(dayxx) 'numbers pressed if dayx>0 then eflag=1 exit do endif end if loop print "days " dayx case 5 'Weeks cls gui page 7 CtrlVal(weekxx) = "##Weeks" print "Weeks selected" do if PDnEf=1 then 'input box touched PDnEf=0 weekx=ctrlval(weekxx) end if if PUpEf=1 then ' numbers entered and ENT touched, ENT generates a Pen Up interrupt PUpEf=0 weekx=ctrlval(weekxx) 'numbers pressed if weekx>0 then eflag=1 exit do endif end if loop print "weeks " weekx case 4 'Months cls gui page 8 CtrlVal(monthxx) = "##Months" print "Months selected" do if PDnEf=1 then 'input box touched PDnEf=0 monthx=ctrlval(monthxx) end if if PUpEf=1 then ' numbers entered and ENT touched, ENT generates a Pen Up interrupt PUpEf=0 monthx=ctrlval(monthxx) 'numbers pressed if monthx>0 then eflag=1 exit do endif end if loop print "Months " monthx case 8 'Done 'store value as a forward DTG to file eflag=1 exit_flag=1 end select loop while eflag=0 print "select ended" eflag if exit_flag =1 then 'all done exit sub endif loop end sub sub abs_entry gui Page 3 do if PDnEf=1 then 'input box touched PDnEf=0 dtg$=ctrlval(15) end if if PUpEf=1 then ' numbers entered and ENT touched, ENT generates a Pen Up interrupt PUpEf=0 dtg$=ctrlval(15) 'numbers pressed if dtg$<>"" then 'eflag=1 exit do endif end if loop gui page 4 end sub sub penDown PDnEf=1 return end sub sub penUp PuPEf=1 return end sub end |
The GUI PAGE command does work and I'm not sure what you mean by "it will not draw multiple times". Perhaps you are expecting it to do something other than its intended function? Your example code does not help as it is way too big to reverse engineer. If you could cut it down to just a few lines (<10) that demonstrates just your problem the answer might become obvious. Geoff Geoff Graham - http://geoffg.net |
It would also help if you told us your OPTIONs It does look like you are doing a CLS while you are still on PAGE 2 (in a number of places). I am the last person to give advice on GUI programming, but that doesn't look right. Jim Edited 2024-02-28 14:31 by TassyJim VK7JH MMedit |
TassyJim Thanks for this, you were correct, for some reason it dosent like a CLS before a GUI PAGE. A CLS is not needed anyway because the previous page is hidden by the new GUI PAGE command. Martin |
| KeepIS Guru Joined: 13/10/2014 Location: AustraliaPosts: 2286 |
FYI: On the rare occasion that you might need to use CLS, simply switch to a dummy page number first before using CLS. NANO:Inverter V 8.4ks - Linux AvrDude GUI script V4.1 |
Thanks Mike I've RTFM and on page 71 it says that a CLS also does a GUI HIDE ALL . The CLS now works as I had expected by my issuing a GUI SHOW ALL after the CLS. |
| twofingers Guru Joined: 02/06/2014 Location: GermanyPosts: 1782 |
Just one question: what is RETURN for? Regards Michael |
Yeah, you don't want to be doing a RETURN in MMBasic unless you are using a legacy GOSUB call. Instead either flow through to END SUB or return early with EXIT SUB. I'm surprised it isn't all "exploding horribly" in the current state. Best wishes, Tom Edited 2024-04-02 21:44 by thwill MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
Manual, Obsolete Commands and Functions. |
