Local Time 03:03 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : For materp: Raspberry Pi 400
LeoNicolas
Posted: 10:21pm 18 Feb 2024
Probably, it is another dumb question. This idea just came to my mind.
How hard is it to port the Mite to a Raspberry Pi 400?
It will be awesome to start the Raspberry Pi 400 and see the MMBasic environment
It has USB ports, IO ports, HDMI, a keyboard, etc...
Amnesie
Posted: 10:35pm 18 Feb 2024
This would be a dream come true and I was afraid to ask this before... Sadly I think this would be really hard work if even possible at all.
So maybe another question for Peter: If not possible to port MMBASIC to the Raspberry Pi, may it be possible to port MMBASIC for Windows to ARM (Raspberry Pi OS)?
But yes, Imagine the power of the Raspberry Pi 400 running MMBASIC with GPIO functions or even HDMI... uff a whole new era would rise :D
But I am VERY happy with PicoMiteVGA, too :)
Greetings
Daniel
Edited 2024-02-19 08:36 by Amnesie
Posted: 10:41pm 18 Feb 2024
Ages ago I did a full port of MMbasic to the Pi but every new version of the H/W and every operating system update broke it. I will never touch that cursed device again
hitsware2
Posted: 11:02pm 18 Feb 2024
  matherp said  Ages ago I did a full port of MMbasic to the Pi but every new version of the H/W and every operating system update broke it. I will never touch that cursed device again
How about a version for this ?
my site
Posted: 11:08pm 18 Feb 2024
I got a rpi 400. key presses say 3. haven't used it, the keyboard fails it seems. could use a usb or bluetooth but rpi400 is not much use as a pc substitute, too slow,youtube is jerky.
I got freebasic working on rpi400 and compiled gcbasic but never messed with wiringpi for fb which would be like mmbasic I guess. fb does sprites I think
hitsware2
Posted: 11:36pm 18 Feb 2024
  stanleyella said  I got a rpi 400. key presses say 3. haven't used it, the keyboard fails it seems. could use a usb or bluetooth but rpi400 is not much use as a pc substitute, too slow,youtube is jerky.
Yes, the keyboard is somewhat flaky.
The 4-B with 4G is quite nice.
For online use try FydeOS ...
my site
Posted: 12:24am 19 Feb 2024
If you are hoping for a bare metal implementation for the Pi then you are out of luck. Of the shedders who like to hear themselves talk only @matherp appears to have anything close to the correct skills and sufficient free-time and he has (IMO sensibly) dismissed the idea.
If you are looking for MMBasic as an application then follow my "signature" to MMB4L (MMBasic for Linux) and find the armv6l release of v0.5.0. That should run on the 400. Any developer worth their salt should be able to compile v0.6.0 too, and for ARM64 if they want.
Alas no high-res graphics, audio or gpio (except by using SYSTEM to call sysfs) yet, and the serial comms whilst usable is best regarded as experimental.
I've just started work this weekend on adding graphics support using SDL2, but don't hold your breath as I'm exceedingly busy and it's not the only iron I have in the fire.
By all means feel free to contribute but note that not only am I probably too busy to coordinate I'm also a brutal code-reviewer .
Edited 2024-02-19 10:25 by thwill
LeoNicolas
Posted: 02:51am 19 Feb 2024
I was thinking of something more bare metal. Something we can write on an SD Card, put in the machine, and that's all... the MMBasic environment will be there.
It was just a dream
hitsware2
Posted: 03:24am 19 Feb 2024
  LeoNicolas said
It was just a dream
Dreams need a little help .....
my site
Posted: 08:38am 19 Feb 2024
TBH I'd much rather have a CMM2 than a RPi. It's more useful to me and has more GPIO, including ADC, which is sadly lacking from the RPi. I must confess to having a bit of a  soft spot for Python though, it's rather like BASIC on steroids. :)
Of course, if you want a RPi-format module that runs MMBasic it's already been done a few times.
Edited 2024-02-19 18:40 by Mixtel90
Posted: 11:06am 19 Feb 2024
  LeoNicolas said  Probably, it is another dumb question. This idea just came to my mind.
To be honest, I never really understood the market niche that the Raspberry Pi 1,2,3,4, and 5 are in. That accounts almost same for the Pi-400. You spend around 100 euro's for a (linux) computer, but to be able to use it typically you need a 100+euro screen, and in many cases external storage (100 euro+ USB3-SSD).
So you are 300+ euro spending to have "Kabelsalat" on your desk (a mess of wires and cables). Especially if you need sound as wel, and a mouse.
Starting from 350 euro's you have a brand new laptop, with everything integrated, having W10 installed, or 200 euro's for a refurbished one.
I do see the value of the Raspberry platforms in embedded applications .. absolutely. But not as a desktop replacement. Or ... to play MMBasic games on. Take the laptop, install MMB4W (or the MMB4L if you like linux - or MMB4W in Wine if you like linux).
Bare metal would be faster ... that is true. I am sure bare metal on a Pi5 if you use multiple cores (so you need some form of an OS !) could be faster. But in the end you would need support for HDMI, WIFI, network, controllers, USB sticks, Bluetooth, etc. And then bare metal forces you to develop everything yourself (let's call it "peter-self"). Un-doable within even one lifetime.
My 5 cents.
Edited 2024-02-19 21:09 by Volhout
Posted: 11:23am 19 Feb 2024
For a long time I used a Pi3 mounted (VESA mount) behind a display on my electronics workbench with a wireless keyboard and mouse. I would run MMB4L on this and use it as a terminal for working with 'mites. It is very space economical because the keyboard and mouse can just be moved to a shelf above when unneeded. That said more recently for development of the Game*Mite I've mostly been working in my office and using my new / 2nd hand Lenovo T480 laptop running Ubuntu.
Edited 2024-02-19 21:25 by thwill
hitsware2
Posted: 02:35pm 19 Feb 2024
( my $0.05 ) :
Pre uefi , I sort of agree .
BUT being one who enjoys swapping OS ' s,
the RPis are the cats meow ( a quick SD switch and PRESTO new OS )
Obviously I'm part of a minority, but I cannot see
how anyone endures Windows and the attendant system oversight.
I even have my Wife converted to RPi 4 with FydeOS ..... : )
my site
Posted: 03:10pm 19 Feb 2024
Hi Hitsware,
All major distributions can be installed in a UEFI environment.
Some BIOS's can be set to legacy mode.
Posted: 03:12pm 19 Feb 2024
I use TwisterOS. it can LOOK like win 98,7,10,11, mac os. You still got to use linux terminal though to do "stuff", yawn :(
hitsware2
Posted: 03:14pm 19 Feb 2024
But not with nearly the ease ( cheap P.C.s anyways ) as before ....
my site
hitsware2
Posted: 03:18pm 19 Feb 2024
  stanleyella said  I use TwisterOS. it can LOOK like win 98,7,10,11, mac os. You still got to use linux terminal though to do "stuff", yawn :(
Yes .... I've managed to run some Windows programs with Twister ..
my site
