Local Time 03:02 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : 32bit counter range extend to 64bit
PhenixRising
Posted: 01:08am 16 Feb 2024
Anyone know of a nifty way to do this? I do have a carry and borrow flag. I can come up with a clunky way of doing it but I'm obsessed with efficiency
EDNEDN
Posted: 02:20am 16 Feb 2024
I would think the natural way to do this is have the 32 bit counter interrupt when it rolls over.   And the interrupt routine would increment a 32 bit integer.   Combined, the 32 bit integer (as the high order bits) and the 32 bit counter (as the low order bits) form a 64 bit counter.
Posted: 08:28am 16 Feb 2024
And one piece of advise..
Make sure this interrupt (32 bit counter roll over) the highest level interrupt in your system.
I have been chasing ghosts for weeks because once in a while another interrupt was executed right between the 32bit counter roll-over, and the increment of the other 32 bit counter. The non matching high and low 32 bits seemed like going back in time, and that upset the algorithms.
P.S. MMBasic (CMM2/H7/Pico) uses 64bit variables.
Edited 2024-02-16 18:29 by Volhout
Posted: 08:37am 16 Feb 2024
For interest - this is the code from the Pico SDK which returns a 64-bit timer from two 32-bit registers
uint64_t time_us_64() {
   // Need to make sure that the upper 32 bits of the timer
   // don't change, so read that first
   uint32_t hi = timer_hw->timerawh;
   uint32_t lo;
   do {
       // Read the lower 32 bits
       lo = timer_hw->timerawl;
       // Now read the upper 32 bits again and
       // check that it hasn't incremented. If it has loop around
       // and read the lower 32 bits again to get an accurate value
       uint32_t next_hi = timer_hw->timerawh;
       if (hi == next_hi) break;
       hi = next_hi;
   } while (true);
   return ((uint64_t) hi << 32u) | lo;
The Pico timer increments every 1uS so 64 bits will overflow every 585 thousand years
PhenixRising
Posted: 09:00am 16 Feb 2024
Thanks guys. The counter is good for 40MHz. Interrupt might struggle
Posted: 09:40am 16 Feb 2024
  matherp said  For interest - this is the code from the Pico SDK which returns a 64-bit timer from two 32-bit registers
   uint32_t lo;
   do {
       hi = next_hi;
   } while (true);
I'm surprised that works without any use of volatile!
Posted: 10:34am 16 Feb 2024
All registers are defined volatile
typedef volatile uint32_t io_rw_32;
typedef const volatile uint32_t io_ro_32;
typedef volatile uint32_t io_wo_32;
typedef volatile uint16_t io_rw_16;
typedef const volatile uint16_t io_ro_16;
typedef volatile uint16_t io_wo_16;
typedef volatile uint8_t io_rw_8;
typedef const volatile uint8_t io_ro_8;
typedef volatile uint8_t io_wo_8;
typedef struct {
   _REG_(TIMER_TIMEHW_OFFSET) // TIMER_TIMEHW
   // Write to bits 63:32 of time
   io_wo_32 timehw;
   _REG_(TIMER_TIMELW_OFFSET) // TIMER_TIMELW
   // Write to bits 31:0 of time
   io_wo_32 timelw;
   _REG_(TIMER_TIMEHR_OFFSET) // TIMER_TIMEHR
   // Read from bits 63:32 of time
   io_ro_32 timehr;
   _REG_(TIMER_TIMELR_OFFSET) // TIMER_TIMELR
   // Read from bits 31:0 of time
   io_ro_32 timelr;
Posted: 10:55am 16 Feb 2024
  matherp said  All registers are defined volatile
Hooray :)
