Local Time 02:13 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Interfacing CGCOLORMAX2-B TO COLORMAXIMITE2-GENERATION 2
allie
Posted: 01:47pm 04 Feb 2024
Hi all
I have the CGCOLORMAX2-B with (3) 5 volt relays on board controlled by ULN2803AN
which is controlled by MC74HCT245N, relays will select (3) stepper motors on a milling  machine.
I want to interface the CGCOLORMAX2-B digital input lines D3,D4,D5 with the digital output lines from the Colormaximite2 generation 2.
Question? Should I put a 74HCT245 or 74HC245 or 74LVC245 between the CGCOLORMAX2-B AND COLORMAXIMITE2, reason being for when they power up and I have to start the programs on the SD cards. On start up will the I/O pins be stable enough that it will not do harm to either boards. This is why I think I should use a 245 which can be HZed with a pull up resistor until the computers startup then the COLORMAXIMITE2 can control the enable line.
The reason I want to use the 245 is there is one already on the CGCOLORMAX2-B board for the relays and there are 5 unused I/O left which I can use.
Best Regards allie
Posted: 04:23pm 04 Feb 2024
If you are linking the two machines together using D3, D4 & D5 I'd suggest simply putting series resistors in the lines as IO protection. Anything between 1K and 10K should be fine. You aren't asking them to supply current (CMOS inputs have a very high resistance) so the volt drop will be negligible. It's a cheap and easy solution and it doesn't matter what state the pins are in - there won't be any damage.
Welcome to the 'Shed. :)
allie
Posted: 10:13am 26 Feb 2024
I put 10k resistors on the I/O's from CGCOLORMAX2-B to the COLORMAXIMITE2G2 and all seems to work O.K.
Thanks for your reply'
Allie
