Local Time 03:50 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : How do I read a single byte from the com port
Gbbickerton
Posted: 07:49pm 02 Feb 2024
I am using
INPUT #3,var
to read a byte from com1 but I am getting an error message
ERROR : line is to long
VAL(INPUT$(1,#3)) returns a 0
so how do I do it?
Posted: 07:56pm 02 Feb 2024
dat$ = INPUT$(20, #5) ' get up to 20 characters from the serial port
dat$ = INPUT$(1, #5) ' get 1 characters from the serial port
then you want either
x = val(dat$)
or
x = asc(dat$)
Gbbickerton
Posted: 08:00pm 02 Feb 2024
That would be the same as VAL(INPUT$(1,#3)) which returns a 0
Posted: 08:06pm 02 Feb 2024
Try PRINTing the character to see what it is.
for VAL to give something other than zero it has to be characters 1 to 9
asc() will also tell you what the character is.
As mentioned in your other thread, make sure you have allowed enough time for the character to arrive before trying to read it.
Gbbickerton
Posted: 08:17pm 02 Feb 2024
So does INPUT$(1,#3) return a binary value between 0 and 255 in the form of a string, if so how do I turn it into an integer?
Gbbickerton
Posted: 08:19pm 02 Feb 2024
I am sending binary data not text I want to read binary data into variables.
Posted: 08:24pm 02 Feb 2024
Did you try
x = asc(dat$)
INPUT$(1,#3)  returns a single byte.
You can treat it as a character or a binary number 0 - 255
That is up to you.
Posted: 09:14pm 02 Feb 2024
In the other thread, you said you were sending from a PICAXE. PICAXE can be set to send serial with either "idle high" or "idle low". If you don't get the values you expect, try sending from the PICAXE with the other idle setting.
Gbbickerton
Posted: 10:03pm 02 Feb 2024
The Picaxe is set right i can receive ascii text ok.
INPUT$(1,#3) returns a string you cannot use var = INPUT$(1,#3) that gives an error
its turning the string into an integer that is the problem.
It looks like asc() might do the trick, it looks like it gives the binary value for the ascii character. thats not in the picomite manual though.
Posted: 10:56pm 02 Feb 2024
  Quote  It looks like asc() might do the trick, it looks like it gives the binary value for the ascii character. thats not in the picomite manual though.
Yes it is in the manual:
  Quote  ASC( string$ ) Returns the ASCII code (i.e. byte value) for the first letter in ‘string$’.
Posted: 12:05am 03 Feb 2024
The description of ASC() can be misleading.
All it really does is get the value of the byte (the first char of the string passed to it) and return it as a number (so, in the range 0-255).
You could do such as
var = asc(input$(1,#3))
(Whereas VAL() turns a sequence of ASCII digits from a string into a number.)
If your incoming data is really groups of 4 bytes which you want to treat as 32-bit integers there's going to be a faster way (other than the value1 + value2*256 etc) to dig them out that's likely a bit unreadable.  As a Pico is really quite fast, try the readable way and see if it's good eough...
Edited 2024-02-03 10:09 by JohnS
Posted: 12:31am 03 Feb 2024
It's tricky getting 32-bit integers out of the Picaxe, with defined 8-bit and 16-bit integer variables.
Why not just send the values as ascii text--easier for a human to understand, and easy enough to covert into integers with VAL? If speed is an issue, increase the baud rate.
Better assistance might be available if it was known what the numbers represent, how fast they are coming, and what needs to be done with them.
