Local Time 03:49 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Victory over a Rotary Encoder on Picomite
apalert
Posted: 05:48am 31 Jan 2024
Feel it's worth sharing this. My task today was to get a rotary encoder working with my current Picomite project. Started with Geoffs notes in "Getting Started With The Micromite". Got it working, sort of. The problem is inconsistency as many before me have discovered. Adding 100nF switch bounce caps as per Geoffs book helped, as did using external pullup resistors instead of the internal ones as per an Arduino forum. But still quite glitchy.
I'd kicked off around 6:30am. By mid-day I was getting frazzled!
Gut feeling said it was still a switch bounce problem. Swapped out the 100nF caps for 2.2uF and magic happened! I'd call it 99.9% cured. The only fault I can get out of it is if I twist the RE knob a large amount as fast as I can it doesn't increment or decrement the total number of times it should. Maybe the caps cant recover fast enough? Might try an intermediate values sometime, say 1uF.
Should I diode protect the pico inputs with 2.2uF caps connected directly to them?
And I'll add, switching back to the internal pullup resistors reintroduced a small amount of inconsistency.
Posted: 06:22am 31 Jan 2024
@matherp has a cure for that here:-
https://www.thebackshed.com/forum/ViewTopic.php?TID=10568&PID=124755#124755#124755
PhenixRising
Posted: 06:24am 31 Jan 2024
If speed is an issue, the Mikroe Click "Counter" board features the LS7366 quad-counter. Easy to talk to (SPI) and can count up to 40MHz @ 5v. Slower if 3v.
Posted: 06:33am 31 Jan 2024
2.2uF seems very high.
I guess it depends on the encoder but I have no issues with 0.1uF.
An external pullup of about 10 is my preference rather than relying on the internals.
Posted: 08:37am 31 Jan 2024
I wouldn't use anything above 100nF (0.1uF) across a rotary encoder contact. They are very flimsy things unless you buy expensive encoders. Repeatedly having a relatively large capacitor discharged through them won't help their longevity.  :(
Peter's software, as Phil99 mentions, works extremely well without capacitors. Well, it does for me. :)
apalert
Posted: 12:17pm 31 Jan 2024
  phil99 said  @matherp has a cure for that here:-
Thanks, yes, I did find Peters code but it threw up errors and I felt daunted to try and fix it. However, you prompted me to take another look.
Immediately after Peters post in that link you sent me another TBS member, goc30, posted a revision of part of Peters code that fixes the problems I was having.
And yes, it works beautifully even without caps or external resistors.
Dave_K1SWL
Posted: 02:13pm 31 Jan 2024
  apalert said  Feel it's worth sharing this. My task today was to get a rotary encoder working with my current Picomite project. Started with Geoffs notes in "Getting Started With The Micromite". Got it working, sort of. The problem is inconsistency as many before me have discovered. Adding 100nF switch bounce caps as per Geoffs book helped, as did using external pullup resistors instead of the internal ones as per an Arduino forum. But still quite glitchy.
(New user here- sorry for the lengthy quote)
I use series resistors of a few hundred ohms outboard of the switch-bounce caps.  They cut down on the discharge current transients.  I'm using the Pico in transceiver designs. Those resistors go a long way toward cutting down on noise impulses as I tune around in frequency.  -Dave_K1SWL
Posted: 03:14pm 31 Jan 2024
That's an excellent idea, Dave.
...and welcome to the 'Shed. :)
