Local Time 05:35 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Question about PLAY WAV
Frank N. Furter
Posted: 05:12pm 21 Jan 2024
Is it possible that the PicoMite crashes if the path is too long?
The following program:
Option Explicit
Dim WAVbusy As INTEGER
Const TRUE=1
Const FALSE=0
Print "Play"
 WAVbusy=TRUE
 'Play WAV "B:\_Lakesidebox+Zwitscherbox\birds-in-forest-on-sunny-day_birds-in-forest-on-sunny-day.wav",IROUTINE
 Play WAV "B:\_Lakesidebox+Zwitscherbox\birds-in-forest-on-sunny-day--Kopie14444hallo.wav",IROUTINE
 Loop While Wavbusy=TRUE
Sub IROUTINE
WAVbusy=FALSE
It is the same WAV twice, just with a different name.
The first line (currently deactivated) works.
The second leads to this error:
Play
Error: Invalid address - resetting
Is this due to the path length?
Frank
These are my settings:
PicoMite MMBasic Version 5.08.00
OPTION SYSTEM SPI GP10,GP11,GP28
OPTION FLASH SIZE 4194304
OPTION COLOURCODE ON
OPTION HEARTBEAT OFF
OPTION PICO OFF
OPTION LCDPANEL ST7789_135, LANDSCAPE,GP8,GP12,GP9,GP25
OPTION SDCARD GP23, GP18, GP19, GP20
OPTION AUDIO GP2,GP3', ON PWM CHANNEL 1
Edited 2024-01-22 03:14 by Frank N. Furter
Posted: 09:45pm 21 Jan 2024
Latest PicoMite manual p19.
  Quote  The maximum file/path length is 63 characters.
Frank N. Furter
Posted: 07:44am 22 Jan 2024
Hi Phil,
THANK YOU! This is exactly the information I was looking for!
Frank
