Local Time 06:27 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Modbus
PhenixRising
Posted: 09:29am 16 Jan 2024
Does anyone have a copy of the code that was on FoTS?
I have downloaded Daniel's HTTRACK (thanks Daniel ) and I see the CRC stuff but not the actual protocol.
Posted: 10:11am 16 Jan 2024
Hi Phenix,
The CRC calculation is currently build into PicoMite (MATH CRC16). It is a generic CRC calculation, you just need to provide the seed and poly.
Modbus uses CRC16-IBM (a variant of CRC16)
CRC overview
and
Python CRC overview
Edited 2024-01-16 20:29 by Volhout
PhenixRising
Posted: 10:26am 16 Jan 2024
  Volhout said  Hi Phenix,
CRC overview
Ah, misunderstanding
CRC is not the problem; the actual Modbus comm's protocol was posted on FoTS but I can no-longer find it.
disco4now
Posted: 11:47am 16 Jan 2024
Temporary static copy of FotS
Look here under M for MODBUS
F4 H7FotSF4xGT
PhenixRising
Posted: 12:05pm 16 Jan 2024
  disco4now said  Temporary static copy of FotS
Thanks Gerry but already have this....it's just the CRC stuff.
I remember that the Cap'n published actual Modbus comm's protocol (coils, registers, etc.)
Did i dream it?
Posted: 12:20pm 16 Jan 2024
Modicon Modbus protocol
Not 'Mite specific, this is general.
PhenixRising
Posted: 01:27pm 16 Jan 2024
Thanks Mick,
This was my first plan but I was certain that an MMBasic sample was already on FoTS.
I'll create it when I actually need it.
Turbo46
Posted: 07:16pm 16 Jan 2024
I put the Modbus CRC stuff on FoTS but their is no other reference to Modbus in there.
The reference guide is slanted towards Modicon PLCs and the reference to coils, holding registers and register addresses don't make understanding the protocol easier. Most of it is irrelevant to most modern implementation. The Modbus protocol is fairly simple really, you only need to implement the commands you need.
Posted: 07:51pm 16 Jan 2024
I think most of the PLCs that use Modbus tend to use a similar concept of coils, contacts and registers - at least as an option. The main thing is to keep with the same header and packaging system if possible. The data is up to you. The detail in the Modicon document is specific, but the basic info near the beginning is relevant to all Modbus systems, I think. You have to remember that it's designed as a high reliability industrial system so keeping close to the spec is an advantage.
PhenixRising
Posted: 07:59pm 16 Jan 2024
If I understand this correctly, this waveshare module will convert to/from Modbus TCP.
Turbo46
Posted: 08:11pm 16 Jan 2024
It Looks like it but I have no experience with Modbus TCP. All our applications used Modbus RTU and were not PLCs.
disco4now
Posted: 09:41pm 16 Jan 2024
Is this post helpfull
F4 H7FotSF4xGT
PhenixRising
Posted: 11:10am 17 Jan 2024
Many thanks, guys. Yeah this stuff is no big deal...KISS principle.
SimpleSafeName
Posted: 12:49am 18 Jan 2024
  Turbo46 said  It Looks like it but I have no experience with Modbus TCP. All our applications used Modbus RTU and were not PLCs.
It's my understanding that Modbus TCP is actually Modbus RTU encapsulated in a TCP packet. And because of the encapsulation, there are a couple of quirks that come with it.
1) The CRC16 checksum is no longer necessary, since the TCP packet will take care of that.
2) It opens up the possibility of multiple masters.
But it's been a hot minute since I messed with Modbus.
When I worked for Schneider we saw plenty of interesting adaptations of the Modbus specs. :)
PhenixRising
Posted: 06:06am 18 Jan 2024
Ah-ha, I was wondering about this very thing.
Edited 2024-01-18 16:07 by PhenixRising
SimpleSafeName
Posted: 11:26pm 18 Jan 2024
Yeah, but...
To a certain extent, Modbus is an example of an open protocol that has descended into chaos. So while it might not be necessary to include the checksum, the "wrapper" that encapsulates the packet takes what has been given to it, which surely came with a CRC already calculated.
And while it is one thing for you to ignore the CRC on your end when receiving a packet, I'm going to guess that the target for your packets on the other end won't be as forgiving.
And were you aware that the CRC16 result needs to have the bytes swapped? Usually.
I created a CRC16 routine in VB and PowerBasic many moons ago, and VB gave me nothing but trouble when I swapped the bytes. Finally I converted the result to Hex$, and swapped those character pairs around and then converted it back to decimal.
Posted: 09:02am 19 Jan 2024
Yeah - Modbus is a "standard" of which everyone uses their own version.
To appreciate its true beauty you have to go back to the days of hardware UARTs and logic chips. That's how it was designed to be used. Forget what people have done to it when they've emulated it in firmware / software because they are usually in the wrong!
SimpleSafeName
Posted: 12:58am 20 Jan 2024
  Mixtel90 said  Yeah - Modbus is a "standard" of which everyone uses their own version.
It's still very effective, and at the heat death of the universe it will be cockroaches and Modbus as the last two standing.
I'm helping out on a project destined for Antarctica, and since it's an upgrade from a Rockwell PLC to a Turck TBEN PLC we may have to use Modbus to communicate to the HMI.
But while working for Schneider I can recall three instances of outside vendors telling us that we had it wrong. :)
Turbo46
Posted: 01:30am 20 Jan 2024
  Quote  Yeah - Modbus is a "standard" of which everyone uses their own version.
Surely if you implement the commands as defined in the Modicon Modbus Protocol Reference Guide systems must be compatible with each other.
PhenixRising
Posted: 02:03am 20 Jan 2024
  SimpleSafeName said  it's an upgrade from a Rockwell PLC to a Turck TBEN PLC
That's some nice looking hardware
Switching away from Rockwell is always an "upgrade"
If I never use that stuff ever again, it will still be too soon
