Local Time 05:45 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MSX 0 and MSX 3 are coming
LeoNicolas
Posted: 04:50pm 11 Jan 2024
Dr. Kazuhiko's keynote regarding the new MSX0 (IoT) and MSX3 computers
https://youtu.be/c_E_vVcocgg?si=2NHhBQIp2_ba25vf
PhenixRising
Posted: 09:09pm 11 Jan 2024
Well I watched it but I have no clue what I watched.
The MSX0 hardware is existing M5Stack products with different colored plastic. This is what Annex32 can run on.
Guess I need help to understand.
Edited 2024-01-12 07:11 by PhenixRising
Posted: 09:00am 12 Jan 2024
Phenix,
They used the MSX microsoft basic, and create an environment (hardware and software) around it to bridge the 40 years.
Some of this is exactly what Geoff and Peter have done.
Make the basic interpreter more up to date and add sensor (peripheral) support. Then port it to multiple platforms (STM32 / PIC32 / RC2040).
They picked ESP32 for the MSX0.
The "strong" selling point is that they target to be 100% backwards compatible. So your old games/catridges can still be played. You can even upgrade your 40 year old MSX computer with a catridge to the new standard.
But honestly ... a 40 year old computer may not be reliable anymore ... How many of the millions of MSX computers will already be put in the trash can ?
P.S. Annex32 runs on ESP32. Haven't played with it recently, but I used the 8266 version on a NodeMCU. It is a WIFI based basic interpreter. With peripheral support. So much is identical. But no backward compatibility to anything. It is unique.
Edited 2024-01-12 19:04 by Volhout
PhenixRising
Posted: 10:04am 12 Jan 2024
Yeah, bit of a dog, performance wise but apart from WiFi and Bluetooth, they also support CAN and Ethernet.
Just musing about the combination of this and the ArmMite H7.
Posted: 02:03pm 12 Jan 2024
  PhenixRising said  [bit of a dog
Depends on what you want to use Annex32 Basic for. The ESP32 S2Mini for about $2.25USD won't be playing Petskii Robots, but for most home automation tasks, it's more than adequate. I have it replacing devices which cost me more than 10 times as much a few years ago.
PhenixRising
Posted: 02:18pm 12 Jan 2024
Do you happen to remember which CPU speed this was?
I see that some devices run @240MHz
Posted: 03:08pm 12 Jan 2024
I'm pretty sure I added those numbers for the ESP32 D1Mini, but it might have been for the original ESP32. I just ran that benchmark for the S2Mini:
0.016    0.344    0.622    0.582    0.701    0.979    2.360    1.311
I don't think Annex gives you an option to change the CPU speed.
Posted: 03:11pm 12 Jan 2024
It still depends on what the application is. Annex on the ESP32 is an IoT device that is still current. ByPic has been unsupported for years and I, for one, would never recommend it for anything important because of that. The Pi Zero in its wireless form is not a cheap option now (£12.50 each as opposed for 3off ESP32 for £19 from Amazon).
PhenixRising
Posted: 03:38pm 12 Jan 2024
No, the question is only about ESP32...I have seen mention of 160MHz and 240MHz on the Annex32 site. Just trying to understand what speed this benchmark reflects.
Posted: 03:46pm 12 Jan 2024
  Mixtel90 said  3off ESP32 for £19 from Amazon).
Or 5 for $10.60USD from Aliexpress, including shipping:
(Though I would only get the version with PSRAM--I'm not sure Annex can be flashed without it.)
Edited 2024-01-13 01:53 by lizby
PhenixRising
Posted: 07:16am 13 Jan 2024
Welp, still no clock-speeds forthcoming. I see that the options are 80|160|240
@lizby
One of their users complained that the latest firmware was slower than the previous version. It was fixed but the example given was for incrementing a var to 50000.
This is similar to benchmark #2 but the time that you posted suggests that 50000 would take >11 secs. Their time is ~3.5 secs.
This seems to indicate that your tests were @80MHz(?)
Phenix
Posted: 02:18pm 13 Jan 2024
  PhenixRising said  your tests were @80MHz(?)
No idea. I briefly looked at some of the Aliexpress listings for the ESP32 S2Mini and none of them specified the CPU speed.
For my purposes, if they're fast enough to respond to a PIR or door sensor reading, they're as fast as I need them to be.
cicciocb
Posted: 03:03pm 13 Jan 2024
for info
https://www.thebackshed.com/forum/ViewTopic.php?TID=16059&PID=207247#207247#207247
Edited 2024-01-14 01:03 by cicciocb
Posted: 04:04pm 13 Jan 2024
  cicciocb said  for info ...
So in the form of previous benchmark posts, with ESP32 and ESP32-S3 provided by the author of Annex Basic, and ESP32-S2Mini by me:
ESP32:       0.009    0.084    0.161    0.159    0.198    0.278    0.56    0.277
ESP32-S2Mini 0.016    0.344    0.622    0.582    0.701    0.979    2.36    1.311
ESP32-S3:    0.008    0.065    0.124    0.119    0.149    0.218    0.41    0.211
PhenixRising
Posted: 07:13pm 13 Jan 2024
Wow... thanks
I totally love modern Basic
LeoNicolas
Posted: 09:38pm 13 Jan 2024
I posted this topic because it would like to show how we need to appreciate Geoff and Petter work to bring a easy to program language to de IoT world. MSX 0 is doing the same as what the MMBasic and all hardwares it can run l, but much more late
