Local Time 06:33 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Setting RTC From NTP
Andrew_G
Posted: 03:30am 02 Jan 2024
Hi All and belated seasons greetings.
I'm fiddling with getting the Date/Time from NTP, having retrieved the Daylight Saving status from OpenWeather.
NTP automatically updates DATE$ & TIME$ but, as far as I can see, one must then update the RTC by say :
RTC SETTIME MID$(Date$,7,4)+","+ MID$(Date$,4,2)+","+MID$(Date$,1,2)+"," +MID$(Time$,1,2)+"," +MID$(Time$,4,2)+"," +MID$(Time$,7,2).
Is there sense in having a command like "RTC SETTIME NOW". It would be up to the user to only use this before the internal clock drifted (or have I lost the plot again?).
Cheers,
Andrew
Edited 2024-01-02 13:31 by Andrew_G
Posted: 04:43am 02 Jan 2024
There is probably a better way , use Val(Mid$() to extract each value from DateTime$(now) and insert them in RTC SETTIME
Posted: 05:20am 02 Jan 2024
I don't have a WEBmite with an external RTC to test but this should do it:
RTC SETTIME LEFT$(DATETIME$(NOW),6)+RIGHT$(DATETIME$(NOW),9)
Posted: 05:32am 02 Jan 2024
Error : Date/time format
This might do it.
sub RTCSet
 local integer y,m,d,h,min,s
 y = val(mid$(datetime$(now),7,4))
 m = val(mid$(datetime$(now),4,2))
 d = val(mid$(datetime$(now),1,2))
 h = val(mid$(datetime$(now),12,2))
 min = val(mid$(datetime$(now),15,2))
 s = val(mid$(datetime$(now),18,2))
 RTC SETTIME y,m,d,h,min,s
end sub
Edit
Repaired a dumb mistake, had "m" twice
Edited 2024-01-02 15:57 by phil99
Posted: 06:33am 02 Jan 2024
I can't count!
try
rtc settime LEFT$(DATETIME$(NOW),6)+RIGHT$(DATETIME$(NOW),11)
Posted: 06:52am 02 Jan 2024
Yes, that is much easier.
When I searched the manual the RTC chapter made no mention of using a string, just coma separated values.
Though it is in the Command section, next revision perhaps?
Edit
This also works.
rtc settime date$+" "+time$
The above uses a 4 digit year without a problem, the Command description only shows 2 as in Jim's example.
Edited 2024-01-02 17:16 by phil99
Posted: 07:41am 02 Jan 2024
If it is happy with the 4 digit year
RTC SETTIME DATETIME$(NOW)
Andrew_G
Posted: 07:10pm 02 Jan 2024
Thanks Jim and Phil.
(I too had assumed that it wouldn't accept a 4 digit year)
I'm thankful on two counts, one that MMBasic had the feature and two that you found it.
Cheers,
Andrew
Posted: 02:49am 03 Jan 2024
Setting RTC From GPS
A little off topic but may be useful if a GPS module is configured.
> If gps(valid) then rtc settime gps(date)+" "+gps(time)
> ? time$, gps(time)
13:43:19        13:43:19
Edit
For better synchronization.
If gps(valid) then
 t$=gps(time)
 do while t$=gps(time)
 loop
endif
Edited 2024-01-03 13:26 by phil99
Posted: 11:10am 03 Jan 2024
This should be in the user manual.
