Local Time 08:12 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMB4W mystery: map.inc error - Invalid here
LeoNicolas
Posted: 06:11pm 27 Dec 2023
Hello everyone
I need help to solve a mystery. I'm refactoring the Knightmare game source code, moving some functions and subs from the main source file to include files. There is one sub called replace_block that I moved to the map.inc file and is causing the game to crash with the following error:
Error in map.inc line 8: Invalid here
The game works fine if I move the function back to the main file (km.bas)
If I change the map.inc line 8, moving the variables declaration to the top of the sub, the error changes to:
Error in map.inc line 11: BLOCK_IX is not declared
I committed the code to a branch called refactoring. These changes are not in the main branch!
Here is the link for the branch: https://github.com/leonicolas/knightmare-cmm2/tree/refactoring
I much appreciate your help.
Posted: 06:23pm 27 Dec 2023
You have end sub in line 5 . Suspect you mean exit sub
LeoNicolas
Posted: 06:26pm 27 Dec 2023
Thank you Peter, that solved the mystery
Nothing is better than some friend's eyeballs to quickly find a mistake in the middle of a bunch of code.
