Local Time 07:23 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : What can we get with the Mites?
PhenixRising
Posted: 10:45pm 26 Dec 2023
Away from my rig so can't test
Posted: 11:03pm 26 Dec 2023
0.009683 seconds MMB4W I7-12700
Edited 2023-12-27 09:03 by matherp
PhenixRising
Posted: 02:23am 27 Dec 2023
It's a bit late/early but the F4 looks to be about 2091.725 milliseconds.
Will try H7 later
Posted: 04:01am 27 Dec 2023
Hi All,
Running the code as listed causes errors so I changed all the variables like EM# to EM etc then it hit a CSNG(EM#) command that fails so I replaced that with a plain EM.
The program now runs but it reports 11.xxxxxx seconds even though it calculates it apparently immediately (no discernible delay).
Now it reports the result (incorrectly at 11seconds as it is) but errors with a STOP command.
What have I done wrong here? I expect a similar result to Peter's as i have an i7 11700
Kind Regards,
Turbo46
Posted: 06:25am 27 Dec 2023
That got me too Mick. The timer is in milli-seconds. Use:
630 EM=(TIMER-SM)/1000
My MM2 takes a bit over 5 seconds.
Posted: 08:39am 27 Dec 2023
Line numbers and GOTOs?
Sigh.
Posted: 08:50am 27 Dec 2023
CMM2 G2
0.274076 seconds
PicoMite 378MHz
0.899028 seconds
Edited 2023-12-27 18:59 by matherp
PhenixRising
Posted: 12:05pm 27 Dec 2023
  JohnS said  Line numbers and GOTOs?
Sigh.
Yeah that's messed up. As soon as I discovered QB4.5 (mid-80's), both those things were eliminated.
PhenixRising
Posted: 01:53pm 27 Dec 2023
  matherp said  CMM2 G2
0.274076 seconds
PicoMite 378MHz
0.899028 seconds
Nice
As much as it pains me to use FB, I might just join the group and post these results.
Can't tell what their DOSBox equates to.
In my QB4.5 days, it was something like 386+387 @ 33MHz (?)
Justplayin
Posted: 04:22pm 27 Dec 2023
0.007813 seconds MMB4W  AMD Ryzen 9 7945HX
Edited 2023-12-28 02:27 by Justplayin
Posted: 06:10pm 27 Dec 2023
Hi Bill, All,
  Turbo46 said  That got me too Mick. The timer is in milli-seconds. Use:
Ahh, thank you, so my PC with MMB4W runs the code in 0.011 seconds! That makes sense as I see no delay from starting till it finishes.
The power of the PC is amazing running interpreted basic. I also own a copy of Power Basic Console Compiler, I will see if I can get it to run on a modern PC ( if I can get the floppy disks onto my new pc, hmm that might be an issue)
Mick (the Big one)
PhenixRising
Posted: 09:25pm 27 Dec 2023
  bigmik said  Hi Bill, All,
Fantastic product! Bob Zale kept it real! I seem to remember a standalone Hello World in 15K bytes
I have PBCC4 and PBWIN8 on my DropBox. Might see if they'll install without p/w.
Edit: No-go. Don't have serial numbers. Have emailed PowerBasic, dunno if they'll cooperate.
Edited 2023-12-28 08:22 by PhenixRising
Posted: 01:50am 28 Dec 2023
I was worried until I realised that the test was only for 50 places.
As a comparison to show that better algorithms can compensate for hardware, try this from a few years ago
BlueberryPi.zip
On MMB4W, 121mS for 1000 digits compared with 6 seconds.
It's not all due to the linenumbers!
Justplayin
Posted: 03:04am 28 Dec 2023
Okay, with the BlueberryPi.bas test with MMB4W I get 41 mS for a 1000 digits on my new laptop.
--Curtis
