Local Time 08:57 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : limiting decimal places to two when reding AIN port
desitech
Posted: 08:21am 21 Dec 2023
I am reading the input from a Analogue port and want to restrict the reading to two decimal places.
I cant find a math function to do this.
Can anyone assist?
Regards - Graham Hobbs
Posted: 08:25am 21 Dec 2023
In displaying the value:
print str$(pin(gpx),2,2)
In limitting the value's resolution
value=int(100*pin(gpx))/100
Edited 2023-12-21 18:27 by Volhout
Posted: 08:26am 21 Dec 2023
Assuming this is for output then use STR$(). Otherwise a2=cint(a*100)/100
Posted: 10:05am 21 Dec 2023
  desitech said  I am reading the input from a Analogue port and want to restrict the reading to two decimal places.
Can anyone assist?
If you store the value in floating point, you can't. There will always (*) be a slight deviation from the exact number you'd like to store.
Typically what is stored is plenty good enough, especially as in your case where the thing you're reading is itself not entirely accurate.
If you really wanted to store it exactly you'd have to jump through some hoops e.g. store 100 times the value as an integer.
(*) nearly always, i.e. except in a few cases where what can be stored is the same as what you want, but these are few
Note: the above is about an inherent issue with floating point on all computers using it. You may have seen the same issue using a calculator and doing such as division by 3 then multiplying by 3 and not getting back the original number.
Edited 2023-12-21 20:06 by JohnS
desitech
Posted: 11:29am 21 Dec 2023
Thanks to everyone for your prompt and great assistance
Graham Hobbs
