Local Time 10:24 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : WebMite Email
palcal
Posted: 05:24am 06 Dec 2023
Firstly I just want to say I am flying blind.
I want to use the webmite to send an email, previously I used an ESP8266 and ESP basic.
I have opened a Send Grid account and got an API key. Then the manual says
  Quote  To get started you need to create a free login at SendGrid and generate an API key which is a 79 character alpha numeric string that is used to authenticate your access to their servers. This key then needs to be converted to a Base64 encoded string (using https://www.base64encode.org ) which will result in a 92 character alpha numeric string.
I have done this but found that if I do it again it generates a different number. Shouldn't the number generated always be the same for the same API key.
Edited 2023-12-06 15:25 by palcal
Posted: 11:00am 06 Dec 2023
  palcal said  if I do it again
Do what again?  You are doing a few things in your post.
If it is generating the Base64 encoded string, it should not change (assuming that you are inputting the same string).
