Forum Index : Microcontroller and PC projects : Question about MP3 with VS1053 module
| Frank N. Furter Guru Joined: 28/05/2012 Location: GermanyPosts: 1162 |
Hi, I would like to set up an audio book reader. To do this, it would be necessary to start an MP3 file at a certain point and remember this new position when stopping, as these files often have a playing time of 1/2 hour or more. If I understand correctly, our "PLAY MP3" command can only start the file from the beginning. Is there (another) way to start MP3 files only at a certain time index? THANKS!!! Frank |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12071 |
You have already asked this and got no reply because, as you are presumably asking me, I have no idea and don't intend to investigate. Why don't you do the work to look at how to construct a mp3 header and edit a mp3 file to trim it to a specified point and then insert a suitable header at the beginning of a shortened file |
Hi Peter, thanks for your reply - I wasn't sure if you had read my entry. I was hoping there was an easier way to achieve it. A web radio also gets a continuous stream (without a header?) and I was hoping it would be possible (with a trick) to jump to a certain point in the file to start it from there... Thanks anyway!!! Frank |
AFAIK streamed mp3 is constant bitrate and each frame is self-contained and any data before a frame start will be ignored by the codec. Normal mp3 files are variable bitrate so there is no way of knowing where in the file a certain playback time will occur without reading from the beginning and essentially decoding the data as you go. |
Ok, thank you very much for your explanation! Then it won't work that easily... |
I've had an idea - watch this space |
Frank - see the "back to beta" thread Edited 2023-12-02 20:10 by matherp |
@Peter: Thank you very much for your efforts! I can't wait to try out your new commands! Frank |
| Plasmamac Guru Joined: 31/01/2019 Location: GermanyPosts: 620 |
like this also , thx a lot Plasma |
A further question, Peter. :) Is it likely that treble, bass and EarSpeaker control might be included at some point? Mick Zilog Inside! nascom.info for Nascom & Gemini |
