Local Time 10:26 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Hot spot telnet to Pico W
Bizzie
Posted: 10:50pm 30 Nov 2023
Hi all,
Let me say I am a complete noobie to all this web stuff.
I would like to use my mobile to telnet to a Pico W.
I have setup a hotspot on my phone and have an SSID and password.
On a brand new Pico W I have loaded - WebMite MMBasic Version 5.07.08RC4
and setup the WIFI an option list shows:-
OPTION WIFI AndroidAPc620, ********, PICOE6614C311B5
From Telnet on win 10.
If I now repower the Pico from a USB charger I can not connect from the Android phone. I have tried 3 different clients (Phone WIFI disabled and hotspot enabled).
Has anyone suceeded doing this, if so what app did you use?
Rob White
andreas
Posted: 12:23pm 01 Dec 2023
The pico is not as robust as a standard PC in regard of wireless connection. Possibly you have to check the network connectivity inside the pico and do a reconnect in the case that there is no connection.
Sub Connect
 Do While MM.Info(TCPIP STATUS) <> 3
   If Timer > 6000 Then CPU restart
 Print "IP: ";MM.Info(ip address)
so "Connect" checks if 6 seconds after reboot/powerup there is no connection then it will restart the pico. Often the second try is successfull.
I have put the Connect sub into the library of the pico - so it is always available.
-andreas
Bizzie
Posted: 05:31am 02 Dec 2023
The solution was very simple!!!
OPTION TELNET CONSOLE ON
One of those days!
Rob White
