Forum Index : Microcontroller and PC projects : MMBasic VAR SAVE
Dinosaur![]() Guru Joined: 12/08/2011 Location: AustraliaPosts: 360 |
Hi All If I put a command in my program: VAR SAVE TxValue as the only variable I want to save, do I need to do anything else before turning the power off?I am getting a zero value in TxValue when I put this at the start of the program: VAR RESTORE Can this be placed anywhere in the program, or does it have to be in Sub MM.STARTUP. Second question, how important is case with Options from the command line ? Edited 2023-11-25 15:49 by Dinosaur Regards Hervey Bay Qld. |
I have a feeling that you have to define all the variables BEFORE calling VAR RESTORE. If a variable has not been defined, and you try to restore its value via VAR RESTORE, it will fail, as there is no defined variable for the interpreter to update in the variable name table. I might have that totally wrong, and modern versions of the FM might automatically CREATE the variable, if it does not exist during a VAR RESTORE, but I do remember in the past having to define and initialize the variables in the code BEFORE doing a VAR RESTORE before it would work. Again, I am only going on my memory for this, and I might have that wrong, but it would not hurt to define "TxValue" first, and THEN issue the VAR RESTORE command. Smoke makes things work. When the smoke gets out, it stops! |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12071 |
You need to define arrays but not simple variables. You should call VAR SAVE when the variable has a value that needs saving. It is not some sort of automatic system that keeps a variable saved as it changes |
Hi All Thanks for the response guys. What I did was: CLEAR OPTION EXPLICIT OPTION DEFAULT NONE DIM AS STRING IP$,Tyd$,Err$ Dim as Float TxValue Dim Integer CalTime,mSec,StepNbr,StartTime,CommFlag Dim Integer StartTime0,Delay0 'variables for each Task Dim Integer StartTime1,Delay1 Dim Integer StartTime2,Delay2 Dim Integer StartTime3,Delay3 Dim Integer StartTime4,Delay4 Then all the subs, the main one being: SUB Initialize ON Error Ignore VAR Restore Print "Var Restored;";TxValue If MM.Watchdog Then Print "Watchdog reboot happened" Err$ = "WatchDog" EndIf StartTime0 = mSec 'So that next delay is correct StartTime1 = mSec StartTime2 = mSec StartTime3 = mSec StartTime4 = mSec WatchDog 300000 '5 min before reboot End Sub If the order of execution is correct then will have to find other reasons for it not working. I did have some problems with different version of my program loading from a different folder and wondering why it did that. If I open a file in MMEdit, then press Transfer to MMCC and then RUN, it should run the program open in the editor. Will put the backups well away from the directory structure and try again. Should the declarations be AFTER the MM.STARTUP ? Edit again:There is something basic I am missing. If I power down the program starts from the very beginning. (the print statements show me that) If I Ctrl C out of the program and then type RUN, I get a completely different start point ?? Print "Nbr of Variables= ";MM.INFO(VARCNT) produces 0 FOUND IT: FreeBasic habit of "Dim AS Float" should be DIM FLOAT and you can't put any statements inside the MM.STARTUP other than the "RTC GETTIME" I will get there. ![]() Edited 2023-11-25 20:11 by Dinosaur Regards Hervey Bay Qld. |
| disco4now Guru Joined: 18/12/2014 Location: AustraliaPosts: 1159 |
There is a difference between restarting MMBasic and restarting your program. A restart of MMBasic is initiated by power being applied, the RST button being pressed or the CPU RESTART command. Each of these will cause MMBasic to restart. The MM.STARTUP routine is searched for and if found any code in it is then executed. If OPTION AUTORUN ON is set then any program in the program memory is run, otherwise the command prompt is shown. The RUN command will clear any variables and then run the program in memory, but does not search for MM.STARTUP. So you only get MM.STARTUP if MMBasic is actually restarted. F4 H7FotSF4xGT |
Hi All Thank you for that information. So, the real question for first time users of MMBasic is: Which documentation applies to my setup, so I don't pester members with mundane questions. I appreciate the time spent creating extensive doc's (which MMBasic certainly has). But if I use a Rpi-Pico W and happen to pick the Webmite image ?? Regards Hervey Bay Qld. |
Since you have a WEBmite, that is the best manual to start with. https://geoffg.net/webmite.html Scroll down to the bottom of the page. It is also a very good idea to read the latest beta/RC threads to see whats in the next version. Jim VK7JH MMedit |
