Local Time 11:07 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMiteVGA: Print only to USB console?
vegipete
Posted: 04:09am 25 Nov 2023
My searching is proving fruitless so far.
Is there a way to send print statements out the USB console only and not to the VGA screen?
The command OPTION CONSOLE SERIAL works for MMB4W, but not for the PicoMiteVGA.
Print #0, something sends the output to both the console and the VGA screen.
OPTION SERIAL CONSOLE pinA, pinB, B maybe needs 2 free pins for an unused serial port?
Posted: 05:39am 25 Nov 2023
From what I can find, this is not possible.
I guess this cos with the VGA-mite, the assumption is that you will be using the VGA screen as the console, and disabling the VGA output of the console would seem to be counter-productive for the VGA port.
I might be totally wrong.
There might be a way to do it, I just have not found it same as you.
If Peter reads this thread, I am sure he will comment if I am totally off my rocker.
Edited 2023-11-25 15:40 by Grogster
vegipete
Posted: 06:30am 25 Nov 2023
Just to be clear, I still want the VGA showing stuff. TEXT commands appear on screen as desired. Think of it as sending debugging messages out the USB port.
Posted: 07:42am 25 Nov 2023
If you are running a program on a PicoMite VGA and you put a PRINT statement in it that will go to the console on the USB, won't it? If you are at the command line the VGA console and the USB console display the same output.
Posted: 08:18am 25 Nov 2023
OPTION LCDPANEL NOCONSOLE turns off all console output to the screen and leaves it like a LCD display that responds to graphics commands only (including TEXT)
amigawizard
Posted: 08:59am 25 Nov 2023
Yes !  John and I  had used that on the maximite`s
       and on our Olimex boards  running MMX
       before USB CDC  was removed  !
             Wayne  !
amigawizard
Posted: 09:10am 25 Nov 2023
https://www.olimex.com/Products/PIC/Development/PIC32-HMZ144/
      Wayne  !!
Martin H.
Posted: 12:32pm 25 Nov 2023
  vegipete said  My searching is proving fruitless so far.
OPTION LCDPANEL NOCONSOLE (NB tick in manual should be in square brackets)
If used in a program this is a temporary OPTION (useful for debugging with a USB/serial CONSOLE) and disables PRINT output to the VGA display. Graphics commands will continue to work.
If used at the command prompt this OPTION is permanent, both print output and CONSOLE output will be disabled and only graphics commands will output to the VGA screen
btw: also TEXT Command is working on the VGA Screen, If you put the option at the start of your Programm, it is just while the Program is running.
https://www.thebackshed.com/forum/ViewTopic.php?TID=15193&PID=192356#192356
Edited 2023-11-25 22:36 by Martin H.
'no comment
vegipete
Posted: 04:34pm 25 Nov 2023
Thank you, OPTION LCDPANEL NOCONSOLE is exactly what I was looking for, does exactly what I want. And it's written right in the manual in plain sight. Doh.
Posted: 11:14pm 25 Nov 2023
Hi VegiPete, All,
I am not a very good programmer but I would never look for an LCDPANEL command, to be supported,  if I was using the VGA version of MMBASIC.
That’s interesting,
