58kk90 Regular Member Joined: 14/06/2023 Location: United KingdomPosts: 82
Posted: 03:35pm 22 Nov 2023
Afternoon all,
I have a 6 x 4 keypad that came from a piece of salvaged surplus equipment, I would like to use with MMBasic, I know there is support for a 4 x 3 and 4 x 4 but what about 6 x 4?
It is laid out as 6 columns by 4 rows, would it be useable with MMbasic can anyone advise please? I know I could use an Arduino, and was planning to do so, but I would love to actually use MMbasic for something other than simply flashing LEDs's or generating tones etc.
Any ideas please.
Regards Tony.,
matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12071
Posted: 03:52pm 22 Nov 2023
Easy enough to code in Basic. Set up a regular timer interrupt which sets one of the 4 lines low in sequence, the rest high. Set the 6 lines as inputs with pullups and use the PORT function to read the 6 lines looking for anything low
Posted: 05:54am 23 Nov 2023
Yes, you are correct, I could write a dedicated routine, and i'll probably give that a go, just wondered if the existing keypad routine would support a 4 x 6 or 6 x 4 keypad, to save code and time really.
