Local Time 13:48 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Sprite Collition Error
LeoNicolas
Posted: 11:25pm 09 Nov 2023
Hello
I'm having trouble to create a new sprite from inside a collision detection sub called by the collision interrupt. I don't know if it is a bug or a limitation on how the sprite's collision interrupt works.
When I try to create a new sprite from inside the sub the SPRITE(C,0,id) function ends with the error "2 is invalid (valid is 1 to 0)"
I'm uploading a test code. You can move the number 1 sprite using the arrow keys. The error happens when the sprite 1 collides with the sprite 2.
t.bas.zip
