Forum Index : Microcontroller and PC projects : Picomite LCD Demo
| Martin H. Guru Joined: 04/06/2022 Location: GermanyPosts: 1573 |
Good morning I already had this for PicoMite VGA and because I was up so early today, I rewrote it for the Non VGA Pico. A little program to impress friends 'Bouncing Ball Demo by Martin Herhaus 2022 'litle BLIT/Sprite Demo for MM Basic 'LCD Version 2023 Colour RGB(black),RGB(white) Dim s(8,2):sx=0:sy=0 For f=1 To 8:s(f,0)=sx:s(f,1)=sy:Inc sx,80 If sx>319 Then sx=0:sy=80 Next FRAMEBUFFER create:FRAMEBUFFER write f Load image "ball.bmp" an=1:rot=-1:BX=0: BY=0: BDir=1 FRAMEBUFFER write n CLS 'Little endless loop until ESC is pressed Do by=Int(Sin(sn*Pi/128)*160):Inc SN SN=SN And 255 If by<0 Then BY=-BY BY=160-by FRAMEBUFFER write f Blit read 1,s(an,0),s(an,1),80,80 FRAMEBUFFER write n Blit write 1,bx,by:x=bx:y=by Box bx-6,by-6,90,90,6,RGB(white) Blit close 1 Inc an,rot If an=9 Then an=1 If AN=0 Then an=8 Inc bx,bdir:If BX>=232 Or BX<1 Then bdir=-bdir:rot=-rot If Inkey$=Chr$(27) Then Exit Pause 5 Loop FRAMEBUFFER close the required BMP file should be in the same directory. ball (2).zip Edited 2023-10-26 15:32 by Martin H. 'no comment |
Very nice, thank you. Good demo. PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
*%)($&^! double post Edited 2023-10-26 21:34 by lizby PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
basically the great-grandchild of my 6809 assembler version from 1986 for the Dragon 32 Edited 2023-10-26 22:25 by Martin H. 'no comment |
| Amnesie Guru Joined: 30/06/2020 Location: GermanyPosts: 763 |
Wow, nice work! Did I miss something? Where can I get the VGA version? Greetings Daniel Edited 2023-10-26 22:37 by Amnesie |
Hi Daniel it was here but i think it is easier just to add the MODE 2 to this Version here... I wrote this on PicoMiteVGA V5.07.04 there were no sprites, just Blit, in the VGA version. You can take the old version and add a ",0" to the sprite write command to make them opaque Edited 2023-10-26 23:19 by Martin H. 'no comment |
