Local Time 14:39 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Sending binary data via COM (PicoMite)
karlelch
Posted: 09:03am 25 Oct 2023
I am trying to send binary data via a COM port. The data contains zeros and it appears that the sending stops if a zero occurs in the data (because a zero does not make sense in a string?).
This is my example code, it sends position commands to a servo controller:
Option Base 0
Option Explicit
Option Escape
Option Default None
SetPin GP5, GP4, COM2
Open "COM2:57600" As #5
Pause 500
Print #5, "\&84\&01\&70\&2E"
Print Lof(#5)
Pause 1000
Close #5
If the second byte (=the servo number) is not zero (e.g., \&01), it works: The respective servo moves; Lof(#5) = 252, indicating that the whole sequence was put into the out buffer.
If the second byte is zero (\&00), the servo does not move and Lof(#5) = 255, suggesting that the sequence was incomplete?
How do you send zero-containing binary data? I am sure, I am missing something.
Any help is appreciated.
Best
Thomas
Posted: 09:43am 25 Oct 2023
Try chr$(0) for the zero character or use bin2str$ to create the string
Edited 2023-10-25 19:47 by matherp
karlelch
Posted: 10:02am 25 Oct 2023
  matherp said  Try chr$(0) for the zero character or use bin2str$ to create the string
Wow - that works. Did not expect that to be qualitatively different from \&00, that why I did not think of trying it
Thanks!
pwillard
Posted: 12:36pm 26 Oct 2023
A "0" and a '\00' are very different with regards to the ASCII encoding performed with serial data transfers.  For example, the ASCII NUL character '\00' is used to denote the end of the string in C or C++. When a programmer uses a "0" (Ascii character for 0) it is treated as 0x30 in hexadecimal number notation. The decimal equivalent is 48.
Edited 2023-10-26 22:38 by pwillard
karlelch
Posted: 12:58pm 26 Oct 2023
  pwillard said  A "0" and a '\00' are very different with regards to the ASCII encoding performed with serial data transfers.  For example, the ASCII NUL character '\00' is used to denote the end of the string in C or C++. When a programmer uses a "0" (Ascii character for 0) it is treated as 0x30 in hexadecimal number notation. The decimal equivalent is 48.
Yes, thanks. I see.
In the manual it says "\&hh The byte whose value is given by hh… interpreted as a hexadecimal number". Hence, I expected "\&00" = Chr$(0). And indeed:
> option escape
> ? Hex$(Asc(Chr$(0)), 2), Hex$(Asc("\&00"), 2)
00      00
> ? Asc(Chr$(0)) = Asc("\&00")
1
But in my example (see first post) it was not equivalent.
Best
Thomas
Posted: 03:28pm 26 Oct 2023
The OPs' original code should have worked but it looks like the parser has a bug. I'll look at it for the next RC
karlelch
Posted: 02:56pm 27 Oct 2023
  matherp said  The OPs' original code should have worked but it looks like the parser has a bug. I'll look at it for the next RC
Thanks!
