Local Time 16:15 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Hopefully something useful
Malibu
Posted: 05:10am 25 Oct 2023
As the title says, hopefully this is something that might be useful that others might want to try out...
My idea is using a WebMite running a stand-alone control system, with a local VB6 program running to easily setup complex parameters and transfer the data to the WebMite.
The same setup could be done with a web page on the WM, but for various reasons, I found it easier to do complex math and data inputs on the VB program.
I should also still be able to access 'normal' web pages via a web browser solely for monitoring.
So, what I've come up with is this (and I was surprised at how simple it was to do)
The WebMite code -
 OPTION EXPLICIT
 OPTION DEFAULT NONE
 option autorun on
 option base 1
Dim string Var1, Var2, Var3
Do While MM.Info(IP ADDRESS) = "0.0.0.0"
 If Timer > 5000 Then
   ? "WiFi Timeout - Reboot"
   Pause 500
   CPU RESTART
 end if
 ? "Waiting for WiFi"
 Pause 1000
? "Connected.  IP address is " + MM.Info$(ip address)
WEB TCP INTERRUPT WebInterrupt
Var1 = "This is variable #1"
Var2 = "Variable number 2"
Var3 = "Another variable (Number #3)"
do
loop
Sub WebInterrupt
 SortData
end sub
Sub SortData
 Local integer a%
 Local Integer b(512)
 for a% = 1 to mm.info(max connections)
   LongString CLEAR b()
   WEB TCP READ a%, b()
   longstring print b()
   if (linstr(b(), "SitRep") > 0) then
     SendSitRep a%
   Else
   end if
 next a%
end sub
sub SendSitRep a%
 web transmit page a%, "/SitRep.html"
end sub
The VB code (Just use a standard form, add a winsock control, a command button and a text box) -
Option Explicit
Dim SockData As String
Const IpAddress As String = "Insert your IP Address here"
Const Port As Integer = 80
Private Sub cmdSend_Click()
 If Winsock1.State = 7 Then
   Winsock1.SendData "SitRep"
 End If
Private Sub Form_Load()
 Winsock1.Connect IpAddress, Port
Private Sub Winsock1_Connect()
 DoEvents
Private Sub Winsock1_DataArrival(ByVal bytesTotal As Long)
 Winsock1.GetData SockData, 1000
 Text1.Text = SockData
 Winsock1.Close
...and a webpage called 'SitRep.html' to the WM like this...
{Var1}
{Var2}
{Var3}
The returned result is this -
  Quote  HTTP/1.1 200 OK
Server:CPi
Connection:close
Content-type:text/html
Content-Length:68
This is variable #1
Variable number 2
Easily sorted by VB6 if needed.
I'm aware that this is probably a completely wrong way to do this, but I found it quick and easy and seems to suit my needs (as a proof of concept, anyway)
Hopefully someone might find the idea worth trying out (Especially those like me that still like and use VB6 [VB.net?... no thanks, it's a nightmare!])
(Forgot to mention, there is absolutely NO error traps or suchlike in any of this code)
Edited 2023-10-25 15:16 by Malibu
DavidAlanRoss
Posted: 12:48pm 25 Oct 2023
Clever combo.
Long live VB6!
I had to embrace Xojo myself, being a Mac and all.
