Forum Index : Microcontroller and PC projects : New Breadboard - Jumperless
| Zonker Guru Joined: 18/08/2012 Location: United StatesPosts: 772 |
Just happened to bump into this video today... Interesting... And, yes, controlling the matrix is an R pie Pico MPU... Watch this Video |
That's very clever indeed. I suspect you can buy a lot of breadboards and jumpers for the price of one though. (And you can have a 100V supply for the ECC83 with wires off its base. :) ) Mick Zilog Inside! nascom.info for Nascom & Gemini |
Yep... Answers the question... Just because you can do something... Should you..?? |
I'm into that, how did I manage with bird's nests all these years? looks amazing.. cost? |
Not available yet AFAIK. You could probably have a lot of custom made PCBs for that price, Stan. Think - the PCBs are about £3.90 for 5 100x100mm, delivered to your door. That isn't all that much more than a breadboard and some jumpers. Mick Zilog Inside! nascom.info for Nascom & Gemini |
Mick please see my vero post and the hidden frustration..means a pcb is nice compared to "vero"... and cheap vero is a waste of time.. tracks lift and they're hard to solder. Wire wool helps but buy vero from RS...er, it's fresher. The ili9341 is a standard display so there must be a pcb for it but at what cost.. postage? |
Depends on what you want, Stan. I did several PCBs. My PicoMite Backpack design might be of interest to you - I can send you one if you like, as you're in the UK. The info about it is in the link in my sig. Mick Zilog Inside! nascom.info for Nascom & Gemini |
Mick has several designs, as do I. JLCPCB costs me $3.87 to have 5 boards shipped to Canada or to the U.S. This PCB can have a 20x2 header, or an ILI9341 with some of the other pins available on the header: PicoMite with ILI9341 Tom's GameMite has an ILI9341. Edited 2023-10-15 07:03 by lizby PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
