Quazee137 Guru Joined: 07/08/2016 Location: United StatesPosts: 603
Posted: 10:40am 14 Oct 2023
> files B:/ <DIR> music <DIR> pgms 2 directories, 0 files >play flac "music" Directory found - commencing player Diadema.flac Vision.flac SVRCINA.flac UMAI.flac CLANN.flac SIRENIA.flac rasputina.flac theb.flac Error : Could not find the file > chdir "music" > play flac "Diadema.flac" > play flac "Vision" > play flac "theb.flac" >
they play when I go into the music dir
any thoughts why its not playing?
Quazee137
Godoh Guru Joined: 26/09/2020 Location: AustraliaPosts: 715
Posted: 12:36am 15 Oct 2023
My partner has a large downloaded music collection, when she gets Flac files, I use Sound Converter to change them to Mp3 files so she can put them on her MP3 player. Her MP3 player won't play FLAC. Sound converter is fast and easy to use. I use Linux Ubuntu on my computer Pete
Posted: 03:23am 15 Oct 2023
I converted them from mp3 to flac so I can play using the PicoMite. The problem is that the PicoMite is not playing the files using
Play Flac "music"
I can change to music DIR and play any and of the flac music files there.
I to use Linux have done so for many many years. I can play all my flac music with VLC and Media player. So I know the files are good.
Quazee137
I am using PicoMiteV5.07.08RC7.uf2 Edited 2023-10-15 13:26 by Quazee137
matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12071
Posted: 07:16am 15 Oct 2023
Sounds like a bug - will fix
UPDATE
Should now be fixed in V5.07.08RC8 if you download it (11:22 UTC 15/10/23) Edited 2023-10-15 21:22 by matherp
Posted: 03:00am 16 Oct 2023
Peter
THANKS
Quazee137
Posted: 07:20am 16 Oct 2023
You should find you don't even need to set to disk b: now Even if the default drive is A: you can still use PLAY FLAC "B:/music"
