Forum Index : Microcontroller and PC projects : PicoGUS - A Pico module based ISA sound card...
Quite interesting to see what others are using the Pico modules for! PicoGUS ISA sound card for retro gaming.... Smoke makes things work. When the smoke gets out, it stops! |
Quazee137![]() Guru Joined: 07/08/2016 Location: United StatesPosts: 603 |
LOL I posted this back on the 7th thinking is may be of use as its open source. And he showed a few other cards making use of the pico. Quazee137 |
Oh, did you?! Sorry for the double-thread then, everyone. Smoke makes things work. When the smoke gets out, it stops! |
Hi All, @Quazzie, I didn't see your earlier post either. I wonder why they used a Pico-W instead of a Pico? Regards, Mick Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
| Plasmamac Guru Joined: 31/01/2019 Location: GermanyPosts: 620 |
This open the world for card with io powered by mmb4w Plasma |
@ Mick - perhaps they only had a W on-hand. As far as I can see from the video, they are not using the WiFi ability at all, so a standard Pico module would probably also work fine. @ Plasmamac - Nice idea, but I don't know that that would ever work. I expect the MMBASIC interpreter overhead would make it too slow to talk to the ISA bus, which I think runs at about 8MHz, so the Pico is PROBABLY using the PIO's and C to be able to talk to the PC ISA bus. I may be wrong, but I don't think MMBASIC would be fast enough for this kind of task. ![]() Smoke makes things work. When the smoke gets out, it stops! |
