Local Time 17:02 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Creating my own ps2 keyboard with MMBasic
Plasmamac
Posted: 09:31am 08 Oct 2023
Hi , id like to build my own  Ps2 keyboard with MMBasic and the pico.
So i need to create the PS2 protocol within MMBasic. What di you think?
Plasma
Posted: 09:42am 08 Oct 2023
It depends on how far you want to go. The simplest PS/2 keyboard (just the basic keys) might be ok, but some keys send several characters. You might find that scanning the keyboard in software isn't very fast, especially if you want rollover detection. Probably fine for ordinary typing but not for gaming.
Lots of info Here
The transmission protocol might be difficult to get the timing right in MMBasic. You may need to use BITSTREAM or even a PIO.
I suggest you try a little ASCII keyboard routine first and see how you get on.
Edited 2023-10-08 19:45 by Mixtel90
Posted: 05:45am 09 Oct 2023
Holtek used to sell a PS/2 keyboard chip in 40-pin DIL, but I don't know if you can get them anymore.
HT82K628A_Holtek.pdf
It would probably be easier to go this route, then to try to have MMBASIC generate the PS/2 codes, as I understand the PS/2 protocol is pretty fast.
Frank N. Furter
Posted: 07:05am 09 Oct 2023
Maybe this will help you?
Arduino ps2dev library
https://github.com/Harvie/ps2dev/tree/15cb56c78ddccfeeeccf4e26e04d2385c380a1f4
Frank
