Forum Index : Microcontroller and PC projects : Serial Communication
MM V5.05.05 throws an error if INV is used with the OPEN command. From the manual pg. 85 . I suspect it is an obsolete command and has been inadvertently left in the manual. Edited 2023-09-20 13:12 by palcal "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
I think that INV was only relevant where the hardware supported it. Jim VK7JH MMedit |
I have a VK2828U7G5LF that works OK with a Micromite, I also have a VK2828U8G5LF, thats with a U8 not U7 it will not work with the Micromite but works OK with a Picomite using the GPS function. What's the difference. "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
INV is usually an option on a "proper" UART or USART but not on a "serial communications module" or whatever they like to call it. If something has a true UART or USART module built in then it may well be supported. If it's only a simulated UART then it may not. What it does, of course, is to allow TXD and/or RXD to be inverted so that they can be connected to inverting line drivers and/or receivers. Mick Zilog Inside! nascom.info for Nascom & Gemini |
If memory serves, the PIC32 hardware serial ports can use the INV option to allow connection to RS232 gear using just rudimentary level conversion. Often just a resistor in the MM2 RX line. I have used it in the past when connected to a laptop for the console. Perhaps INV is only available on COM1: If your modules work on a Pico then they must be TTL serial and don't require inversion. Edit INV should also be available on COM2: but not on any "Embedded C Module" ports. Edited 2023-09-20 18:06 by phil99 |
Yes INV is only available on COM1: and I am using COM2:, which explains the error. I will try COM1: with INV and the GPS module that did not work on COM2: and see if it works. "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
Just tested a MM2 and INV does not throw an error on COM2 if you do it like this:- > OPEN "COM2:9600",inv as #2 > The manual shows it should be like this OPEN "COM2:9600, INV" AS #2 but that gives:- Error : COM specification Have not tested for actual inversion yet. Edit Now I see it in the manual, COM1 only! Edited 2023-09-20 18:54 by phil99 |
OK I finally got this sorted the VK2828U8 version did not work because the sentence we have to look for is not GPRMC but GNRMC "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
the sentence we have to look for is not GPRMC but GNRMC Good to know. Will have to update my old MM+ and MM2 programs. |
Well not yet, I just unplugged from my computer and put on a 5v charger and it has stopped working. I'll look some more but getting close to giving up. I have one of these U8 versions working OK with Geoff's GPS tracker ??? "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
I'll give up on this, it works sometimes and not others, maybe a problem with the module. Edit... still don't understand why it runs on a Picomite OK. Edited 2023-09-22 12:40 by palcal "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
