Forum Index : Microcontroller and PC projects : Chipies!!!
"They're HERE....." (name that quote) ![]() At last! After three years of waiting, I finally am able to now start offering the Explore-64 and Explore-100 boards. 2106 date-code for the 100-pin chips, and 2230 date-code for the 64-pin chips. Can it be true? Can things be starting to get back to normal? (rhetorical!) Smoke makes things work. When the smoke gets out, it stops! |
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 9248 |
Wow...... I've never seen so many pins in one photo before...... :) Mick Zilog Inside! nascom.info for Nascom & Gemini |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 6199 |
After 3 years ..... You have been persistent. Volhout PicomiteVGA PETSCII ROBOTS |
Yes, well, I have some mission-critical systems that run on the MM+ series of chips. Having said that, I have had AT LEAST two of both the 64-pin and 100-pin chips, kept in stock for no other use other then for system-failure kind of use. But now that Microchip seem to have restocked on these chips, I will re-enable sales of the E64 and E100 boards on my website over the weekend. Smoke makes things work. When the smoke gets out, it stops! |
| NPHighview Senior Member Joined: 02/09/2020 Location: United StatesPosts: 222 |
Please - what's the URL for your website? Live in the Future. It's Just Starting Now! |
Hi - Website link... The E64 and E100 boards still list as unavailable, but I will be making them available again on the website over the weekend. Smoke makes things work. When the smoke gets out, it stops! |
