Hansaplast Newbie Joined: 13/07/2023 Location: Hong KongPosts: 15
Posted: 09:44am 13 Sep 2023
The following message by using OPTION SDCARD
> OPTION SDCARD GP24 Error : Pin 42/GP24 is in use
the same happen with
> OPTION SDCARD GP23 Error : Pin 41/GP23 is in use
This can't be, as PIN 42 of the Pi-Pico is VCC (IOVDD) and GP24 is PIN 36
or I'm wrong?? Edited 2023-09-13 19:52 by Hansaplast
circuit Guru Joined: 10/01/2016 Location: United KingdomPosts: 310
Posted: 10:04am 13 Sep 2023
See the Picomite manual page 10;
"On the Raspberry Pi Pico these pins are used for internal functions as follows; Pin 42 or GP24 is a digital input which is high when VBUS is present".
Posted: 10:11am 13 Sep 2023
Yes, I saw
Pin 41 or GP23 is a digital output set to the value of OPTION POWER. (ON=PWM, OFF=PFM). Pin 42 or GP24 is a digital input, which is high when VBUS is present. Pin 43 or GP25 is also PWM4B. It is an output connected to the on-board LED. Pin 44 or GP29 is also ADC3 which is an analog input reading ⅓ of VSYS.
Is there any way to make it working?, as I use the Pi-Pico chip on my own PCB with all ports.
matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12074
