Local Time 20:25 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : EDITor F2 anomalies
carlschneider
Posted: 11:58pm 20 Aug 2023
https://www.thebackshed.com/forum/ViewTopic.php?TID=15968&PID=208064#208064#208083
As previously undertaken herewith observations of the F2 intermittent issues with the program aborting with errors being reported to the console and running successfully with another F2 in response to the abort.
General observations
- The abort to console with error appears to occur after editing of the program
- F2 again will run the program without any abort to console for invalid errors
- the line number of the error to console depends on program structure and moves as the editing moves
- The abort to console line errors appear to me to be errors associated with entering the code before parameters
  are set for commands or jumping into a subroutine
Thoughts on possible causes, albeit from an amateur
- Maybe delay between SAVE and RUN on F2 doesn't provide time to reset the program pointer
- F2 is behaving as a CONTINUE for some reason
- Program pointer is not being reset consistently
I have attempted to provide the information in the following structured format, noting that the program is a work in progress and the line numbers are shifting but not the structure ;
-A. Line of Error reported at console and code at that line
-B. Where I altered the code in the EDITor
-C. Structure of code between where I was working in EDITor and the Line of the error on the console
First recorded instance
A. 17 ADC OPEN 250000,1,ADCComplete
B. Was editing in Sub ADCComplete
C. Structure
Sub ADCComplete
Sub GetModBus
'WriteModbus
ReadModBus
Sub GetFreq
Sub DoMinute
Sub SetPort
Sub AssembleModBusStrings
Sub ReadModBus
Sub WriteModbus
Sub ServiceWebInterrupt
Sub AssembleJSONSTring
Sub AssembleResponseHeader
Second recorded instance
A. 165 WEB CLOSE TCP CLIENT in Sub WriteModBus
B. Editing in Sub ADCComplete
C. Structure
42 Sub ADCComplete
65 End Sub
Sub GetModBus
'WriteModbus
ReadModBus
Sub GetFreq
Sub DoMinute
Sub SetPort
Sub ReadModBus
Sub WriteModbus
Third recorded instance
A. 220 End Sub of Sub ServiceWebInterrupt
C. Structure
Sub ADCComplete
Sub GetModBus
'WriteModbus
ReadModBus
Sub GetFreq
Sub DoMinute
Sub SetPort
Sub ReadModBus
Sub WriteModbus
Fourth recorded instance
A.17 ADC OPEN 250000,1,ADCComplete
C. Structure
Sub ADCComplete
Sub GetModBus
'WriteModbus
ReadModBus
Sub GetFreq
Sub DoMinute
Sub SetPort
Sub ReadModBus
Sub WriteModbus
Hope this helps pinning down what remains an intermittent issue.
For reference
> option list
WebMite MMBasic Version 5.07.08b11
OPTION COLOURCODE ON
OPTION CPUSPEED (KHz) 252000
OPTION DISPLAY 41, 140
OPTION WIFI ***, **********, PICO****
OPTION TCP SERVER PORT 80
OPTION TELNET CONSOLE ON
Cheers Carl
Retirement is tough on Hobbies without a day job
Posted: 12:28am 21 Aug 2023
You haven't said if you are using the TELNET terminal as your console or using the USB.
A MEMORY report would be useful.
Instead of F2, can you try F1 to save and then RUN. That might help isolate the cause.
I have experienced random errors on RUN and the following RUN is OK, but I have not seen it for a while now.
carlschneider
Posted: 01:28am 21 Aug 2023
  TassyJim said  You haven't said if you are using the TELNET terminal as your console or using the USB.
Thanks for the response Jim.
This using USB on a MBPro Mid 2012 running Ventura 13.1 through OpenCore Legacy Patcher. I'm running the Terminal.app and Screen to tie to the USB.
I will attempt to add Memory reports when next logging an anomaly.
I will try the F1 then F2 approach and see if that makes a difference, or do you mean specifically F1 to SAVE and then  typing RUN at the console?
Cheers Carl
Posted: 01:36am 21 Aug 2023
  Quote  or do you mean specifically F1 to SAVE and then typing RUN at the console?
After you have exited the editor with F1, F2 becomes a shortcut to RUN and prints RUN to the console.
For 'Belt and Braces' try both ways.
carlschneider
Posted: 02:19am 21 Aug 2023
  TassyJim said  Instead of F2, can you try F1 to save and then RUN. That might help isolate the cause.
  Quote  After you have exited the editor with F1, F2 becomes a shortcut to RUN and prints RUN to the console.
F1 F2 gave me the same problem again so I then used F1 RUN which gave the same issue.
I'll try doing it over Telnet and see what happens, although telnet is a bit laggy :)
Cheers Carl
carlschneider
Posted: 02:36am 21 Aug 2023
Nope whether I use USB or Telnet its the same or both F1 F2 and F1 run.
I'll try and remember to do the memory report next time :)
Cheers Carl
carlschneider
Posted: 03:01am 21 Aug 2023
I notice on telnet the console is overwriting the EDITor window. Don't recall seeing this occur on USB...
Cheers Carl
Posted: 07:01am 21 Aug 2023
The built-in editor is designed to work using standard ASCII codes through the USB or directly connected TTL serial input. We usually find that any problems are with the terminal emulation setup or the terminal emulator itself, neither of which can be influenced by MMBasic.
The F2 command simply sends RUN<CRLF> to the command line of the editor. If your terminal isn't handling that then you need to sort that out first.
carlschneider
Posted: 01:30pm 21 Aug 2023
Thank you all for the guidance, much appreciated.
Cheers Carl
