Local Time 21:04 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : ON ERROR SKIP examples
Posted: 07:21am 19 Aug 2023
 ON ERROR SKIP 1
 x = k/0
 y = g/0
 z = g/0
As expected, the first divide by zero is skipped and the second line throws an error.
 ON ERROR SKIP 1
 x = k/0 : y = g/0
 z = g/0
Only the first statement on the line is counted when 'skipping'
The second statement after the : will cause an error condition.
 t$ = "999"
 ON ERROR SKIP 1
 x = VAL(t$)/0
 y = g/0
 z = g/0
With builtin functions, the whole statement is treated as one.
The first error trapped is on the following line
(This may not be true for all built-in functions or complex lines.)
 t$ = "999"
 ON ERROR SKIP 1
 x = myval(t$)/0
 y = g/0
 z = g/0
FUNCTION myval(txt$)
 myval = VAL(txt$)
END FUNCTION
With user functions, the call to the function is (more than) one statement  hence the error on that line. The example uses up 3 'skip' statements on the one line.
Edited 2023-08-19 17:22 by TassyJim
Posted: 08:55am 19 Aug 2023
nice concise write-up.
note also that
ON ERROR SKIP 1 ' CATCH ZERO DIVIDE
X=1/0
won't work as you might expect - I think this is probably because ' is treated as REM whic is a statement and so the only 1 command skipped
Posted: 09:10am 19 Aug 2023
Also, ON ERROR SKIP is the same as ON ERROR SKIP 1 as the skip count value is optional and defaults to 1.
Posted: 09:52am 19 Aug 2023
  CaptainBoing said  nice concise write-up.
note also that
X=1/0
It works as expected on the picomite (and MMB4W) - rems are ignored.
ON ERROR SKIP 1
' test
x = k/0
y = g/0
z = g/0
ON ERROR SKIP 1 ' test
x = k/0
y = g/0
z = g/0
both the above ignore the remarks
