Local Time 20:24 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Setting up Pimoroni Explorer Base for the Pico
HLinder
Posted: 03:22pm 18 Aug 2023
Dear all,
apologies if I have missed this topic in my forum search.
I try to get the Pimoroni Base Explorer on-board LCD to work with the current picomite firmware.
The board is working under MicroPython so hardware seems ok.
However OPTION settings in MMBasic led to no success so far.
Did already someone get this to work?
Any help would be wonderful.
Helmut
Posted: 03:30pm 18 Aug 2023
No idea what that display is, and the schematic doesn't tell us either. Do you have any details on it? Model number or anything?
hitsware2
Posted: 03:32pm 18 Aug 2023
I also had a problem with that . If I remember correctly ,
uPython uses different pins ?
In some cases uPython is  much more accessible
than MMBasic .
my site
Posted: 03:40pm 18 Aug 2023
Right, I've looked closer. The only connected signals are MOSI, SCLK, CS and DC. There is no RESET connection so I don't think MMBasic can initialise this display at all. If you can find a RST or RESET pin on the display it may be possible to wire it to another pin and do something with it.
Welcome to the forum, Helmut. :)
Edited 2023-08-19 01:42 by Mixtel90
Posted: 04:13pm 18 Aug 2023
Try tie reset high.
Posted: 04:35pm 18 Aug 2023
AFAIK the display RESET signal has to be toggled to initialise it under MMBasic.
Edited 2023-08-19 02:38 by Mixtel90
HLinder
Posted: 04:40pm 18 Aug 2023
Wow what a fast response.
Thank you so much for the support.
It nags on me since days.
My final attempt was a trial and error approach and that gave success.
These are the settings which did the trick so far.
OPTION SYSTEM SPI GP18,GP19,GP20
OPTION LCDPANEL ST7789, LANDSCAPE,GP16,GP12,GP17
GP20 is a dummy pin with regards to SPI.
Should I close the topic and how is that done?
Helmut
Posted: 04:50pm 18 Aug 2023
There isn't really a way to close a topic. They just sort of degenerate into nothingness. :)
I thought it might be a ST7789, but the schematic connections look strange. I have one of those, but without CS brought out so I had to modify it as it definitely won't work without that signal.
I see the display has a RESET pin but it's hard-wired to a power-on reset circuit. That's why it's working. :)  Yes, MMBasic needs you to specify a pin whether you need it or not.
Derek_H
Posted: 02:43pm 22 Aug 2023
Possible already solved/too late but here are my settings for the Pimoroni Pico Explorer Base.
> option list
WebMite MMBasic Version 5.07.07
OPTION SYSTEM SPI GP18,GP19,GP0
OPTION LCDPANEL ST7789, PORTRAIT,GP16,GP26,GP17,GP20
Derek
HLinder
Posted: 12:51pm 23 Aug 2023
Ultimate proof that SPI only needs 3 wires i.e. those pins our settings have in common
btw. backlight dimming appears to be non-functional on the board.
Posted: 02:33pm 23 Aug 2023
Depends on what you want to do. All the pins are there for a reason. :)
You can't have more than one device on the bus without a CS for each.
You can't read data from a device without MISO.
You can't re-initialise a device without powering down without RESET.
The backlight LED has a fixed current drive from its own chip. You can't vary the brightness without some serious PCB hackery..
Edited 2023-08-24 00:39 by Mixtel90
