Local Time 19:04 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : WebMite + Arducam
led-bloon
Posted: 09:05am 16 Aug 2023
WebCam.bas V1.0 (a misnomer as it most certainly cannot do video!)
A single shot camera function tethered to a WEB server.
Included in zip file index.html, some pictures and a ReadMe text file.
The pictures are a little grainy due to camera too close to subject matter.
Default image size 320x240, however several image sizes are possible.
The image(s) is/are saved to flash file system so should be minimized!
May be of interest to someone
led
Edit; just noticed an error in the html file, final line should be:
</html>
Hope that's all
WebCam.zip
Edited 2023-08-16 19:20 by led-bloon
Miss you George
crazycloud
Posted: 07:50pm 24 Aug 2023
thank you for all the work on this great program.  I got my Arducam and hooked it up successfully.   I can capture a jpg, so I know the camera is functioning.  It does
not transfer to index.html though.
this is what I see as an error.  Line 73 says Invalid  in a program.
I'm don't know what that means.  I did send the jpg via telnet to my pc. I know the arducam works.
> option list
WebMite MMBasic Version 5.07.08b11
OPTION WIFI NETGEAR57, **************, PICOE6614C311B5
OPTION TCP SERVER PORT 80
OPTION TELNET CONSOLE ON
> OPTION COLOURCODE ON
> run
Camera I2C channel pass!
Camera SPI channel pass!
Camera sensor configured
Starting WEB server
Press any key to exit!
[73] If cnt% = 0 Then Continue
Error : Invalid in a program
led-bloon
Posted: 09:39pm 24 Aug 2023
My apologies.
I didn't test the thing after doing some "tidy ups". Big mistake.
Here is v1.1 (tested!)
led
WebCam11.zip
Miss you George
crazycloud
Posted: 08:39pm 25 Aug 2023
It worked like a charm the first time!!!!!
awesome program.  I'm really going to learn a lot study it.  I ordered more cameras
and 4 new PICO W boards.  I have a young technician where I work who is interested
in all things raspberry pi.  I going to give the camera and pico with your program.
crazycloud
Posted: 09:29pm 05 Sep 2023
I'm baffled.  LOL
I built 4 duplicates of the webcam circuit.  None of them work. I swapped cameras
with my original circuit and the "new cameras" work.  I get a time out error
aved 18016 bytes
> run
WEB server started at 00:09:15
Timeout Bytes rxed: 65536
I'm done!
I'm not sure what it means
I edited the line
SPI READ 4096, buf%()  ' Read the data
     For i%=0 To 4095: Print #1 ,Chr$(buf%(i%));: Next i%
     j%=j%+4096: siz%=siz%-4096
Instead of Print #1 I printed to the screen.  there was no data.  I did this on the good working circuit and there was plenty of data.
I got my picos from Amazon and the cameras from Amazon too.  I don't think the hardware is the problem.  I copied out the basic program form the known good circuit
and put it into the 4 bad ones, just too be sure I didn't have an editing problem.
do you know what Timeout Bytes received is telling me?
led-bloon
Posted: 02:42am 06 Sep 2023
This was a known problem (by me and the site I translated from).
Try the latest v1.2 with a bug fix, if not...
There is a Const "SHUTTER" set at 10000 (10 seconds) as an overall
timeout waiting for the camera to complete transfer of the jpg image.
You can either increase that timeout (add 1000 or 2000), and see if
things improve, or add an "ON ERROR IGNORE" to the code.
What size jpg are you expecting to get? (640x480? bigger?)
The fact that you get 65536 rings an alarm bell (flash writes are in blocks
of 256) - will have to do some (non-camera) tests with this.
Hope this is helpful
led
WebCam12.zip
Edited 2023-09-06 13:02 by led-bloon
Miss you George
led-bloon
Posted: 08:25pm 06 Sep 2023
I would hold off on this for now, I think I understand a logic problem
when I clear the interrupt flag. Browsers use multiple threads to request
information (files/images) to speed up the presentation of the WEB page.
Because index.html is a small file, and only requests ONE jpg image, the
current code is probably border-line working (my guess).
I will try changing the logic to account for multiple interrupts.
led
Miss you George
crazycloud
Posted: 08:33pm 06 Sep 2023
This sounds encouraging, thank you.  I did just finish trying webcam12.  I got the same results. I previously tried different jpg sizes, and shutter times. I'll await the next revision.
led-bloon
Posted: 07:34am 07 Sep 2023
Decided to drop using interrupts and just do simple polling.
Easier and seems to work quite well, so please try v1.3.
There's a readme file with extra info.
led
WebCam13.zip
Miss you George
crazycloud
Posted: 10:41pm 07 Sep 2023
I tried version 1.3  Still no pictures.  I swapped cameras. No result
I transferred Test.jpg to my pc.  When I looked at it with a hex editor, its all 00
even though in the directory its 160 kbytes. Very confusing.  Thanks for still trying
this weekend I will hook up an oscilloscope to the camera.
crazycloud
Posted: 05:08am 10 Sep 2023
My error discovered.  Please accept my apology. All versions of your program work fine. My error was swapping GP3 and GP4 in all the subsequent circuits I made.
I now have 6 copies of the camera that work just fine.  Next up is powering the board and camera with a lithium ion cell.  I will try to run it remotely.
led-bloon
Posted: 06:09am 10 Sep 2023
I have made the WebService() sub a little more "bullet proof"
in V1.4, and it is recommended to upgrade.
If you are looking at remote installation, the WEB NTP call
is not 100% guaranteed, use an ON ERROR or Watchdog to get
around any failures, with AUTORUN enabled or add RTC module.
led
WebCam14.zip
Miss you George
crazycloud
Posted: 05:04pm 10 Sep 2023
here is a jpg from the yard via telnet. version 14 seems to run faster.
led-bloon
Posted: 08:44pm 10 Sep 2023
Nice   Puts my yard to shame!
led
Miss you George
