Local Time 22:04 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Serial Port Tracker for Windows
pwillard
Posted: 02:47pm 15 Aug 2023
There are times when I want to know which serial ports are active on my windows PC.
While I *could* fire up TeraTerm to see the list... I sort of wanted to have a little window where I could see active ports.
Result: This super-simple python script...
I figured I would just share it.
# Name:        SerialTracker.py
# Purpose:     Simple tracker for active serial ports attached to windows PC
# Author:      Pete Willard
# Created:     15/08/2023
# Copyright:   (c) willard 2023
# Licence:     CC BY-NC-SA
import serial.tools.list_ports
import time
import PySimpleGUI as sg
def main():
   layout = [
       [sg.Text("Available Serial Ports:")],
       [sg.Listbox(values=[], size=(40, 10), key="-PORTS-")],
       [sg.Button("Exit")]
   window = sg.Window("Port Tracker", layout)
   while True:
       event, values = window.read(timeout=1000)  # Auto-update every 1000 milliseconds
       if event == sg.WINDOW_CLOSED or event == "Exit":
           break
       refresh_ports(window)
   window.close()
def refresh_ports(window):
   ports = [port.device for port in serial.tools.list_ports.comports()]
   window["-PORTS-"].update(values=ports)
if __name__ == "__main__":
   main()
github
DaveJacko
Posted: 10:04pm 15 Aug 2023
I'm a purist..
could this be done with MMBasic for DOS ?
Thanks Pete,
personally think MMBasic could run the world.
Try swapping 2 and 3 over
Chopperp
Posted: 11:10pm 15 Aug 2023
TassyJim's MMCC also gives a good indication of ports added or removed but that would need firing up as well.
I also use this Windows one here
Brian
Edited 2023-08-16 09:58 by Chopperp
ChopperP
