Local Time 21:04 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Unable to write data to Thingspeak
shoots
Posted: 09:21am 14 Aug 2023
Hi, I have tried to write to Thingspeak using a WebMite. I have applied various combinations of IP address for the thingspeak site and ports and always receive  "Failed to connect" error message.
I have marked out passwords.
I have been able send data to thingspeak via a url on a web page using   https://api.thingspeak.com/update?api_key=I01xxxxxxxxxN7&field1=29
This works so I know the thingspeak side of things is OK. I have used my username and tried channel number in the MQTT fields to no avail.
Any suggestions welcome please.
Thank you,
Peter
OPTION EXPLICIT
OPTION DEFAULT NONE
option autorun 1
print MM.ver
dim string channelID$="2xxxx"
dim string apiKey$="Ixxxxxxxxxxx7"
print channelID
print apiKey
'to load via terminal when first running:
'option TCP SERVER PORT 80
'OPTION TELNET CONSOLE ON
'WEB NTP 8     'to get time later
'print TIME$
print MM.INFO(IP ADDRESS)
WEB TCP INTERRUPT WebInterrupt
dim integer CurrentTemp=TEMPR(GP15)'16
dim integer CurrentHumid=80
do
print "test"
pause 10000
loop
sub WebInterrupt  'called when a request is made over the web
CurrentTemp=TEMPR(GP15)   'this is a DB18S20
print "in subroutine"
local integer a,p,t,b(512)
FOR a=1 To MM.INFO(MAX CONNECTIONS)'Loop through all the incoming connections
                        '(there could be a number of simultaneous connections)
print a,"   number of connections"
WEB TCP read a,b()    'Read the incoming message into the long string buffer
print b(a)
p=LINSTR(b(),"GET")   'Get the locations of key words in the message
t=LINSTR(b(),"HTTP")  'Get the locations of key words in the message
'r = LINSTR(array%(), search$ [,start]) Returns the position of a string in a long string
IF (p>0) And (t>p) then
WEB TRANSMIT PAGE a%,"index.html"
print TIME$
print "data ",a," a   ",p," p       ",t," t   MMmax",MM.INFO(MAX CONNECTIONS)
PRINT "Temperature: " TEMPR(GP15)
sendThing
endif
next a
end sub
sub sendThing
WEB MQTT CONNECT "192.168.1.137",1883,"Sxxxx","Sxxxxxx"
WEB MQTT PUBLISH,"&field1","35"
'not working-possible wrong approach  WEB OPEN TCP CLIENT https://api.thingspeak.com/update?api_key=I0xxxxxxxxxxxxxIN7&field1=39
'192.168.1.108  'Tried these IP
'184.106.153.149
end sub
Posted: 09:33am 14 Aug 2023
WebMite can't support SSL over TLS which may be what Thingspeak needs. Not enough resource. Unless they have a non-secure port there is no solution
shoots
Posted: 09:44am 14 Aug 2023
Thank you matherp. Saves me sweating over it. I will give MicroPython a try- a pity as I have been enjoying the MMbasic environment for the last few years.
Thank you for your work on it.
Cheers,
Peter
davematt
Posted: 02:00am 15 Aug 2023
@shoots, dont give up quite yet. In my ignorance I have been using a webmite to send to Thingspeak very reliably for some weeks. Got a hint from another member. Will forward his PM to you. And post code here if anyone else interested…
Cheers, D
Bizzie
Posted: 03:48am 15 Aug 2023
I am sure not only me would like to see the code.
Rob White
davematt
Posted: 08:31am 15 Aug 2023
Hi Rob, your wish is my command...
To my knowledge, this has worked perfectly for 12 weeks, all credit to Peter of course, my cattle and I are extremely grateful.
' Thingspeak Test 1.1
'WebMite MMBasic Version 5.07.07
'OPTION SYSTEM SPI GP10,GP11,GP12
'OPTION AUTORUN ON
'OPTION CPUSPEED (KHz) 250000
'OPTION LCDPANEL ILI9488W, RLANDSCAPE,GP8,GP15,GP9,GP13
'OPTION WIFI ********
'OPTION TOUCH GP16,GP17
'GUI CALIBRATE 0, 231, 3963, 1267, -837
'OPTION SDCARD GP22
option explicit
option default none
option autorun on
Dim m$,s$, n$, api_key$="XXXXXXXXXXXXXXXX"  ' put your thingspeak key here
DIM buff%(4096/8)
m$="GET http://api.thingspeak.com/update?api_key="+api_key$+"&field1="
Getmessage                             ' waits for message from lo ra
 Batt = val(Arg$(3))
 Level = val(Arg$(4))
 Current = val(Arg$(5))
 Status = Arg$(6)
if timer > 1200000 then                           '20 mins
 s$=m$+Str$(Batt,0,1)+"&field2="+Str$(Current,0,1)+"&field3="
 s$ = s$ + Str$(Level,0,0) + chr$(13) + Chr$(10)
 Web Open TCP Client "184.106.153.149",80  'fixed address for Thingspeak HTTP
 WEB TCP CLIENT REQUEST s$, buff%(4096/8)
 Pause 1000
 buff%(4096/8) = 0
 WEB close TCP Client
end if
Posted: 10:48am 15 Aug 2023
Davematt--thanks for posting your working code. Sometimes the key is not knowing that something "won't work".
Note that you can preserve the formatting of your code when posting (which I suspect you had by the single space indent following the "if") by enclosing it within the tags "[ CODE]" and "[ \CODE]" (upper case but without spaces) or by pasting it in after clicking the "code" button above the posting window.
Posted: 11:47am 15 Aug 2023
Or attach as a file.
shoots
Posted: 01:55pm 15 Aug 2023
Hi Davematt, thank you for the encouragement and the program. I will have a go with it. I can see there's more than one way to achieve an outcome when it comes to programming. I spent some time grappling with MicroPython and ended up having a win but it was a tedious process! All good learning though. The little Pico W is a pretty cool item.
Cheers,
Peter
