Forum Index : Microcontroller and PC projects : Question regarding Webmite: Direct connection?
| shellberight Newbie Joined: 21/05/2022 Location: United StatesPosts: 5 |
Is it possible to configure Webmite to allow a direct wireless connection? Example would be to connect my cell phone directly to it to retrieve web browser data without the need to have it connected to a router, then connect to the router, then access the webmite. THanks |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12074 |
The WebMite always runs in station mode. You could probably do what you want by setting your phone as a wireless hotspot and then connecting to it from the webmite |
I wasn't sure if Webmite supported the Raspberry Pi Pico Soft Access Point as shown here: https://microcontrollerslab.com/raspberry-pi-pico-w-soft-access-point-web-server-example Follow up question, does it support html & image objects from a connected SD card? I don't see it indicated in it's documentation. I know that the other two versions of the picomite do support an SD card for additional storage. Thanks |
Yes SD card on the WEBmite is no problem. Jim VK7JH MMedit |
