Local Time 22:07 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Using the onboard led as statusled by changing the delay?
Plasmamac
Posted: 02:15am 27 Jul 2023
Hi
@matherp : is it possible to change the delaytime for the o board led to become a visual status led without extra Hardware and pin?
Plasma
Posted: 03:39am 27 Jul 2023
Set OPTION HEARTBEAT OFF
then use pin(GP25) as a standard digital out
  Quote  Pin 43 or GP25 is also PWM4B. It is an output connected to the on-board LED.
Plasmamac
Posted: 04:49am 27 Jul 2023
Thx Jim , i dunno if i ever read this information mfg
Plasma
Posted: 07:33am 27 Jul 2023
You can have fun with that LED as it's directly connected to TP5 (the middle pad) under the Pico's PCB.
If you directly connect a Red LED from TP5 to GND it automatically takes over from the green one (it has to be red as it it has a lower forward voltage than green).
If you connect a 1K resistor from TP5 to the base of a NPN transistor then the transistor will turn on while the LED is lit. Useful if you are stuck for an output.
This one is slightly riskier, although GP25 has some protection. If you use
HEARTBEAT OFF
SETPIN GP25 DIN
then connect TP5 to 3V3 via a 1K resistor the LED will light and GP25 will read as 1. If you now short TP5 to GND with a contact or a turned-on NPN transistor then the LED will go out and GP25 will read as 0.
