Local Time 23:56 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Uploading files to your WEBmite
Posted: 07:53am 13 Jul 2023
This assumes that you have already enabled TFTP on your Windows PC.
Create a batch file with the following contents.
echo %1
echo %~nx1
tftp -i 10.1.0.232 PUT %1 %~nx1
pause
Save it as a batch file where-ever you put this sort of thing and create a desktop shortcut.
On the WEBmite, change to the destination directory.
Start dragging files onto the shortcut, one at a time.
They upload at a pleasing, fast speed without the padding that XMODEM gives.
Once you are happy that it works, you can dispense with the ECHO lines and the PAUSE.
Linux users should be able to do similar with a shell script but I don't know how to remove the path from the filename in Linux.
Posted: 08:41am 13 Jul 2023
What does echo %~nx1 do?
Need to understand it to convert to Linux :)
Posted: 09:49am 13 Jul 2023
the %1 is the first parameter passed
adding ~nx removes the path leaving the filename with extension. Just what we need on the WEBmite end.
ECHO is just there so you can see the results while experimenting.
I assume you need a regex expression to do the same in Linux. Regex is not my best friend.
Typical output of the above batch file
  Quote  C:\Apps>echo C:\Users\Jim\Documents\myapps\maximite\apps\aatest.bas
C:\Apps>echo aatest.bas
aatest.bas
C:\Apps>tftp -i 10.1.0.232 PUT C:\Users\Jim\Documents\myapps\maximite\apps\aatest.bas aatest.bas
Transfer successful: 65 bytes in 1 second(s), 65 bytes/s
C:\Apps>pause
Press any key to continue . . .
Posted: 10:19am 13 Jul 2023
Linux can use
basename path
to get the last part.
I don't have a webmite but likely something like
tftp 192.168.0.5 -c put "$1" `basename $1`
(if the put command even needs the destination name?)
Edited 2023-07-13 20:28 by JohnS
Posted: 09:18pm 13 Jul 2023
Thanks for the hint.
In my experiments with Linux, I found I needed the TFTP HPA version of TFTP to get it to play fairly in shell scripts.
Based on your suggestion, I would try
terminal -x tftp -m binary 192.168.0.5 -c put "%1" 'basename %1'
terminal needs to be changed to suit and I advise using binary mode so one script handles text as well as images etc.
I also strongly advise using filenames and paths without any spaces in them. Spaces make life "interesting"
Posted: 09:44pm 13 Jul 2023
For Linux the argument needs to be $1 not %1 and the basename part uses back quotes so it's substituted by the result of the basename.
I don't know the terminal command (not on my system).
Edited 2023-07-14 07:45 by JohnS
Posted: 10:04pm 13 Jul 2023
Thanks for the explanation.
This should be better
terminal -x tftp -m binary 192.168.0.5 -c put "$1" `basename $1`
I had trouble getting tftp to run the command properly unless I opened a new terminal session.
On my Mint-Mate, the terminal is called mate-terminal
Other systems call it gnome-terminal
Some just use terminal
If you enter commands at the command prompt, you are in a terminal and there will be a way of opening a new terminal, running a command, then closing the terminal.
My Linux knowledge is sod-all so I expect that I am using the wrong terminology.
Edit:
Changing 'terminal' to 'mate-terminal' (and setting the correct IP) and this script works perfectly.
Edited 2023-07-14 17:47 by TassyJim
