Local Time 00:46 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : BMC Menchester Code
Teo1
Posted: 09:01pm 25 Jun 2023
Can anyone help me decode a BMC-Menchester signal?
Thank you in advance,
Teo
hhtg1968
Posted: 09:46pm 25 Jun 2023
do you talk about
https://en.wikipedia.org/wiki/Manchester_code
disco4now
Posted: 06:53am 26 Jun 2023
This link describes BMC.
BiPhase Mark Code and Manchester Code
It looks to describe a hardware decode.
A PicoMite CSUB to  timestamp pin changes (Manchester code?)
Capturing 433MHz code on Picomite (Manchester code?)
The above links might gives some ideas to decode in software on the Picomite.
F4 H7FotSF4xGT
Posted: 07:43am 26 Jun 2023
Whether you can decode it in MMBasic will depend on the data rate. The Pico itself will very likely be capable, but it's a question of timing - especially when decoding.
Welcome to the forum, Teo! :)
circuit
Posted: 07:39pm 26 Jun 2023
The PICAXE store still lists the NKM2401 chip which is a PIC12F508 microcontroller programmed with Manchester coding/decoding.  Currently listed as out-of-stock.  I have used pairs of these in the past with simple transmitter/receivers and they worked really well.
Datasheet available here:
https://picaxe.com/docs/axe213.pdf
Quazee137
Posted: 09:11pm 26 Jun 2023
The hex file is here NKM2401
 Quazee137
circuit
Posted: 10:11am 28 Jun 2023
  Quazee137 said  The hex file is here NKM2401
 Quazee137
Is it?  I cannot access this page, are you able to download a copy?
Posted: 10:29am 28 Jun 2023
I can see the file at that URL.
Teo1
Posted: 05:26pm 28 Jun 2023
HI,
First of all, thanks so much everyone for your help.
I need to receive the attached signal and convert it to RS232.
The signal is BMC encoded at 250bps speed, consisting of 22 bits.
In the example given, the first byte has a value of 92.The next 12 bits represent the number 1326, the penultimate bit is for parity and the last bit is for stop. Send LSB first.
Sorry for my English.
Any idea, help will be appreciated!
Thanks in advance !
Teo
BMC.pdf
Quazee137
Posted: 05:30pm 28 Jun 2023
Here
NKM2401.hex.zip
 Quazee137
disco4now
Posted: 07:53am 29 Jun 2023
@Teo
Are you thinking of doing this with a Picomite?
Is the data received continuously. Does it repeat the same data until it changes e.g a temperature etc?
What is the line state when there is no data?
How would it be converted to ASCII for the RS232 e.g. output the twenty bits as 5 hex characters. i.e. 52E5C or does it need decoding.
I think it could be achieved with a tweak of one of the above CSUBs.
Gerry
F4 H7FotSF4xGT
Teo1
Posted: 05:52pm 29 Jun 2023
Hi Gerry,
Yes, I use Picomit
Data is received continuously .
Repeat the same data until it changes.
Depends on the state of the last transmission (see attached PDF).
In the example ,in the PDF , we pass 92 in decimal and 1326 in decimal LSB first.
Thanks in advance !
Teo
circuit
Posted: 08:44am 30 Jun 2023
  Quazee137 said  Here
NKM2401.hex.zip
 Quazee137
Thanks for that; when I tried to access the page I was, for some reason, blocked.
Posted: 09:49am 30 Jun 2023
With 250bps you can do the whole decode in basic. No need for CSUB or PIO.
use timer as time reference
use a GPx set for both edges interrupt
loop until bit counter reaches your threshold
analyze array()
in the interrupt routine
- log pin status + time stamp timer to array()
- increment bit counter
MMBasic is fast enough to keep pace with 250bps.
Teo1
Posted: 02:34pm 30 Jun 2023
Thanks a lot !
Teo
Posted: 11:50pm 30 Jun 2023
For anyone else that wants to play with decoding Teo's BMC.pdf this produces the data stream on another PicoMite.
'Generate continuous Manchester code stream
OutPin = 1 'GP0
SetPin OutPin, DOUT
'bitstream intervals  1=2000uS ,2=4000uS, 4=8000uS
Dim integer D(32)=(4,4,2,2,1,1,1,1,1,1,2,1,1,2,2,1,1,1,1,1,1,2,1,1,2,2,1,1,2,1,1,2,2)
Math scale D(), 2000, D()
 Bitbang Bitstream OutPin, 33, D()
Adjust the scale factor if the speed is wrong.
Edited 2023-07-01 18:11 by phil99
