Local Time 01:40 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Bluetooth for Pico W
atmega8
Posted: 08:48pm 23 Jun 2023
https://www.raspberrypi.com/news/new-functionality-bluetooth-for-pico-w/
Now, with the release of version 1.5.1 of the C SDK, and the latest MicroPython build, your existing Pico W has gained the ability to communicate with Bluetooth and Bluetooth LE devices.
Posted: 09:00pm 23 Jun 2023
... if you write the firmware to handle it.
Finished it for you. :)  Having it available in the SDK doesn't mean that it's practicable to include it.
It was announced in February for C programming, IIRC, but hasn't been supported in Python until fairly recently.
Posted: 10:18pm 23 Jun 2023
  atmega8 said  https://www.raspberrypi.com/news/new-functionality-bluetooth-for-pico-w/
As already posted, it's not really new news, but a critical issue is what's the RAM footprint?
aFox
Posted: 08:55am 24 Jun 2023
From
Arduino-Pico Documentation
Release 3.3.0
Earle F. Philhower, III
Jun 20, 2023
23.1 Enabling Bluetooth
To enable Bluetooth (BT), use the Tools->IP/Bluetooth Stack menu. It requires around 80KB of flash and 20KB of RAM when enabled.
Both Bluetooth Classic and BluetoothBLE are enabled in btstack_config.h.
Gregor
Posted: 09:20am 24 Jun 2023
All RAM on the PicoMite is already allocated AFAIK. matherp will no doubt correct me on this if I'm wrong, but to get BT I suspect that you'd probably lose another flash slot and over 20kB of user RAM because RAM allocation may not be splittable where you expect it to be. I can't speak for others, but I'd consider that too much of a loss when it's so easy to add a separate BT module.
aFox
Posted: 07:51pm 25 Jun 2023
A BlueMite version could be possible.
As I said before, it seems that you have to use a LINUX IDE to successfully compile the bluetooth stack.
I tried by Windows and I failed with the simplest examples.
Gregor
