Local Time 01:38 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : micromite stuff?
markboston36
Posted: 02:39am 21 Jun 2023
What happened to all of the micromite stuff that used to be on this forum. i’m finding mmbasic but no software or anything that used to be here.
disco4now
Posted: 04:39am 21 Jun 2023
The micromite software and manuals are on Geoff's site. https://geoffg.net/micromite.html
I think the software for Micromites was always via Geoff's site.
All the old discussions are still on this site I think.
F4 H7FotSF4xGT
Martin H.
Posted: 04:49am 21 Jun 2023
how about the Sticky Topic
Micromite MMBasic Library(s) ?
'no comment
disco4now
Posted: 05:17am 21 Jun 2023
On searching on this forum TBS.
A search for 'Micromite' will return a maximum of 50 results. Most of these will be recent and possibly just reference 'micromite' in discussion around Picomite or  similar. This makes it look like the original items are not there.
You can use google to search by prefixing the search with site:thebackshed.com
You can also add -picomite etc to exclude items with that keyword. e.g.
to search for micromite but not maximite,picomite,mmbasic or ARM use this as the google search.
site:thebackshed.com micromite -maximite -picomite -mmbasic -ARM
F4 H7FotSF4xGT
palcal
Posted: 05:23am 21 Jun 2023
I think Mark may mean no one is talking about MM lately. The Micromite has sort of been on the backburner since the Picomite. I guess just not much to talk about at the moment.
Posted: 06:31am 21 Jun 2023
Probably cos the PIC32 series of chips are still very hard to obtain with any kind of certainty, and so no future firmware developments are happening, cos there are no chips to load the new firmware into.....
Perhaps only a part-problem, but chips are still hard to find, whereas the Pico module is really easy(and cheap) to find, so all the development is for that module and chip for the moment.
Posted: 07:15am 21 Jun 2023
I'm currently playing with a RP2040-Zero and I suspect it takes up much less PCB area than a through-hole 28pin Micromite with through-hole accessories. No bridge chip, ICSP header or 3V3 regulator needed. And it was cheaper (from AliExpress they are, anyway). Not as many IO but I don't need more for this project.
Posted: 07:17am 21 Jun 2023
I think there's no more space in the flash of micromites for the extra functionality now available.
If Microchip had made chips available and created new ones with bigger RAM & flash (at good prices) maybe things would be different.
The RP2040 & boards using it have been a boon.
Edited 2023-06-21 17:18 by JohnS
Posted: 08:18am 21 Jun 2023
After the silicon production dip manufacturers will focus on volume products first (regain market share, make money).
I fear that the volume for through hole microcontrollers could postpone the availability of new micromites (the 28 pin). Maybe postpone until eternity.
Old stock (in your lab drawer) may be your only rescue for these.
Edited 2023-06-21 18:18 by Volhout
Posted: 08:39am 21 Jun 2023
Very few industrial scale customers are interested in through-hole anything now. If it can't be pick-and-place or hand soldered in position very cheaply then they don't want to know. At the moment we are ok for non-silicon components, probably because of the very cheap electronic assembly shops in some parts of the world, but even that may not last as they eventually become more automated.
My ancient eyeballs and increasingly wobbly hands don't think much of SMD. lol
