Local Time 01:38 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite: ILI9341 + touch
Posted: 03:59pm 14 Jun 2023
Hi folks,
I've never had call for it before but thought I better check the that the Bintendo PCB was correctly wired up for the ILI9341 touch interface ... I think it is.
However my older ILI9341 module is reluctant to calibrate, e.g.
> gui calibrate
Warning: Inaccurate calibration
Deviation X = -2147483648, Y = -63 (pixels)
> gui calibrate
Deviation X = -2147483648, Y = 134 (pixels)
> gui calibrate
Deviation X = 450, Y = 143 (pixels)
> gui calibrate
Deviation X = 198, Y = 552 (pixels)
> gui calibrate
Deviation X = 41, Y = -15 (pixels)
> gui calibrate
Deviation X = 153, Y = 370 (pixels)
> gui calibrate
Deviation X = -2147483648, Y = 388 (pixels)
> gui calibrate
Deviation X = 11, Y = 140 (pixels)
> gui calibrate
Error : Touch hardware failure
> gui calibrate
Deviation X = 272, Y = 5 (pixels)
> gui calibrate
Done. No errors
Deviation X = 0, Y = 4 (pixels)
> gui test touch
And even when it does GUI TEST TOUCH either does nothing, or plots points in a vertical line down the left hand side of the screen.
I have another ILI9341 straight out of the anti-static bag that seems to be fine.
Is this likely to just be a case of a (partially) dead ILI9341 ... or more strictly the XPT2046 touch controller ?
Posted: 04:12pm 14 Jun 2023
maybe the touch 5 wire ribbon cable on the right is not making good contact.try touching it and pressing the display connectors down. there is a gap on mine that closes. if it fixes it, glue it.
