Forum Index : Microcontroller and PC projects : Reset Single OPTIONs?
| Calli Regular Member Joined: 20/10/2021 Location: GermanyPosts: 74 |
Maybe I miss something. I need for a test to switch between PWM and SPI audio. Is there a command to clear an OPTION, I mean like OPTION AUDIO OFF? Other that OPTION RESET Best, Carsten |
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 9252 |
OPTION AUDIO DISABLE Mick Zilog Inside! nascom.info for Nascom & Gemini |
| IanRogers Senior Member Joined: 09/12/2022 Location: United KingdomPosts: 152 |
I was playing with this. I think ( and I may be wrong, most of the time this is true ) You can just type the OPTION AUDIO xxxxx and it seems to overwrite the exsisting. My 2 penneth. I'd give my left arm to be ambidextrous |
You might be right, Ian. I've not played with a PWM/SPI setup yet. Mick Zilog Inside! nascom.info for Nascom & Gemini |
To my defense, it is not noted in the documentation near the AUDIO option :) Thanks, Carsten |
