Local Time 02:27 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite connection problem
palcal
Posted: 01:05am 13 Jun 2023
I am unable to connect to any of my Micromites that are using the 1455 USB Serial Interface. MM+ connects and Picomite connects. I have tried a different computer and different cables. Checked Device Manager and driver is OK. ?? Iam running Win11 but tried on my Win10 laptop.
palcal
Posted: 02:08am 13 Jun 2023
I got that a bit wrong, they connect to the port OK but I cant communicate.
On one Micromite that I wasn't using I was even able to update the firmware, but CTR-C
does nothing.
Edited 2023-06-13 12:17 by palcal
Turbo46
Posted: 02:16am 13 Jun 2023
Do you have the correct baud rate set - 38400? What are you using to communicate with. I have no trouble with Teraterm and MMEdit on W10.
palcal
Posted: 02:20am 13 Jun 2023
Baud rate is OK, I have tried TeraTerm, GFX term and MMEdit.
Turbo46
Posted: 02:27am 13 Jun 2023
Power supply? My 'test' Micromite runs off the USB supply.
palcal
Posted: 02:29am 13 Jun 2023
Geez what a dope, I was sure I checked the Baud rate, they were all set to 9600.
All OK, I've been doing this for 10 years and still making silly mistakes.
Turbo46
Posted: 02:39am 13 Jun 2023
Sometimes you just need someone to bounce something off. The forum is great for that.
