Local Time 02:26 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : decode a not standard ir protokoll
Plasmamac
Posted: 03:32am 06 Jun 2023
HI,
I have a cheap Hd Monitor with a Infrared Remote which will not encoded by the intern
Mmbasic picomite protocoll (sony). I got Pulses from the IR Receiver so i guess the frequenz is ok. if i remember right somebody has postet some code  for a problem like what. the search function will not help me so i ask here .
thz
Plasma
Posted: 07:03am 06 Jun 2023
In case it helps, some search sites are better at finding things and allow such as
site:... search words
The ... can be a URL usually.
Edited 2023-06-06 17:03 by JohnS
Posted: 07:42am 06 Jun 2023
I have no idea what Sony protocol you are refering to, but the PicoMite user manual says that there are 2 IR protocols supported:
- NEC
- SONY
When your protocolis different from these two (i.e Philips RC6 or so) then you need to analyze the protocol so we have somthing to work with. Without more detail it is hard to suggest a solution. Most IR RC systems work around PPM (pulse position modulation) where a carrier burst is send, and there is a variable time in between bursts. This time determines if it si a "1" bit or "0" bit that is send.
So accurately measuring the "period" of such demodulated signal will give you infomration about the ones and zeros.
MMBasic (on picomite) is fast enough to keep pace with the bitstream. Measuring could be done using PIO, or the PULSIN command.
Edited 2023-06-06 17:52 by Volhout
Posted: 07:57am 06 Jun 2023
It can only *send* SONY protocol though.
The frequency might be correct (commonly around 38kHz) so the receiver chip is seeing it and flashing the LED connected to it's data pin, but that doesn't mean that the protocol is the same.
IR is tricky. You need to capture the signals from the transmitter and then find a way to copy them if you want to transmit them from something else. A good place to start is with a 38kHz IR receiver and a digital oscilloscope. Get something to display while the transmit button is held down then set the trigger and do a 1-shot display. You have one pulse train on the screen to figure out. :)  Some logic analyzers can do this very well too. It's always difficult with an unknown protocol as you can't trust any of the published codes.
Posted: 08:19am 06 Jun 2023
Peter's CSub LOG can capture the data. Alternatively the ADC function can do it.
At 378MHz a short For - Next loop can capture data with 20uS pulses.
Posted: 09:08am 06 Jun 2023
  phil99 said  Peter's CSub LOG can capture the data. Alternatively the ADC function can do it.
Hi Phil,
Does the LOG csub still work? I remebers disco4now had to recompile it for 50703B13, since the header file changed. Would be nice to have this functionality. But I expect 50703 (1 year ago) might be too old to run.
What would even be nicer, if Peter adapted the PULSIN to accept an array for results in stead of a value. Then yo would not need the CSUB at all.
Posted: 12:22pm 06 Jun 2023
  Quote  Does the LOG csub still work?
The old version no, but Peter updated it after the change of compiler version.
TassyJim has a similar thing called Fetch, I think.
Posted: 09:42pm 06 Jun 2023
This is something I put together for Grogster to read pager codes.
It uses a PWM signal as a high definition timer on a micromite.
you save all the time intervals to an array and then analyze them later.
It might help but the pico has a lot more in it's arsenal.
 ' exp64 decoder
 DIM INTEGER tick, tock, period, pulsetime = 50, synctime = pulsetime * 10
 DIM code$
 DIM pulses(500) '  store all timing intervals for later processing
 DIM inSync ' used to signal when sync pulse has been received
 DIM pulsecount
 DIM firstRun, syncs
 DIM validAlarms$(20)
 CONST ticker = 49 ' connect PWM output (pin 48) to here
 CONST rxPin = 46  ' pin that the receiver output connects to
 validAlarms$(1) = "011101010001110000000010"
 validAlarms$(2) = "011101010001110000100010"
 validAlarms$(3) = "011101010001110001100010"
 validAlarms$(4) = "011101010001110000000001"
 validAlarms$(5) = "011101010101110000000010"
 validAlarms$(6) = "011101011101110110100010"
 validAlarms$(7) = "011101011001110001100010"
 validAlarms$(8) = "011101011001110000000010"
 validAlarms$(9) = "011101011111110000000010"
 validAlarms$(10) = "011101000001110000100010"
 validAlarms$(11) = "011101100001110001100010"
 validAlarms$(12) = "011101010001110001000001"
 validAlarms$(13) = "010101010001110000000010"
 validAlarms$(14) = "011001010001110000100010"
 validAlarms$(15) = "011011010001110001100010"
 validAlarms$(16) = "011101010001110100000001"
 validAlarms$(17) = "011101010001111100000010"
 validAlarms$(18) = "011101010001101000100010"
 validAlarms$(19) = "011101010001000001100010"
 validAlarms$(20) = "011101010000110000000001"
 PWM 1, 100000, 50 ' this is out high resolution timer whch gets connected to ticker pin
 SETPIN ticker, CIN
 SETPIN rxPin, INTB, blip ' triggers on a high or low transition
 tock = PIN(ticker)
 SETTICK 3000, checkit
 DO
   '    IF INKEY$<>"" THEN
   '      decode
   '    ENDIF
 LOOP
END
SUB blip
 tick = PIN(ticker)
 IF inSync = 0 THEN
   IF (tick - tock) > synctime AND PIN(rxPin) = 1 THEN' long enough to have been sync pulse
     inSync = 1
     pulsecount = 0
     pulses(pulsecount) = tick - tock
   ENDIF
 ELSE
   pulsecount = pulsecount + 1
   IF pulsecount > 400 THEN
     inSync = 0
     pulsecount = 0
     'print "overflow"
   ENDIF
 ENDIF
 tock = tick
END SUB
SUB checkit
 LOCAL n, t
 t = TIMER
 decode
 FOR n = 1 TO 20
   IF validAlarms$(n)<>"" THEN
     IF INSTR(code$,"s"+validAlarms$(n))>0 THEN ' we have lift off!!
       PRINT "!!!! ",n, " needs help!"
     ENDIF
   ENDIF
 NEXT n
 PRINT "Checkit time ",TIMER - t
END SUB
SUB decode
 LOCAL n, pulsetimes
 code$ = ""
 ' check every second timing
 PRINT pulses(0)                                          'DEBUG
 pulsetimes = 0                                           'DEBUG
 FOR n = 1 TO 400 STEP 2
   pulsetimes = pulsetimes + pulses(n)+pulses(n+1)        'DEBUG
   PRINT pulses(n), pulses(n+1), pulsetimes               'DEBUG
   IF pulses(n) > synctime OR pulses(n+1) > synctime THEN ' a sync pulse
     code$ = code$ + "s"
   ELSEIF (pulses(n) + pulses(n+1)) = 0 THEN              ' all done
     EXIT FOR
   ELSEIF pulses(n+1) = 0 AND pulses(n) < pulsetime THEN  ' final transition
     code$ = code$ + "0"
   ELSEIF pulses(n) > pulses(n+1) THEN
     code$ = code$ + "1"
   ELSE
     code$ = code$ + "0"
   ENDIF
 NEXT n
 PRINT code$                                               'DEBUG
 inSync = 0
 syncs = 0
 pulsecount = 0
 FOR n = 1 TO 400
   pulses(n) = 0
 NEXT n
END SUB
Plasmamac
Posted: 01:28am 07 Jun 2023
thx Tassyjim , i will check.
i send temp and humidity from near Berlin (180km) . i mean its not Austalia so its near :)
gtx
Plasma
nestorjm
Posted: 02:49pm 07 Jun 2023
  Plasmamac said  HI,
thz
Then maybe you need to send pulses with the NEC IR protocol
You may find the solution in this post  (NECSend command) !
Posted: 03:14pm 07 Jun 2023
@plasma,
Unless you provide more info, we may not be able to help you to a solution.
Plasmamac
Posted: 05:57pm 07 Jun 2023
Hi vollhout, i need to analyze the remote protocol first so i can’t provide much infos.
With Sony protocol i mean the MMBasic provided ir protocol. Thx
Plasma
Posted: 06:27pm 07 Jun 2023
  Quote  Hi vollhout, i need to analyze the remote protocol first so i can’t provide much infos.
If you haven't got a dedicated logic analyser then use Volhout's excellent PIO based logic analyser for the PicoMiteVGA
